Supra PCV install DIY
Old Dec 14, 2008 | 09:05 PM
  #91
s2000Junky's Avatar
Originally Posted by asukadc,Dec 14 2008, 09:56 PM
not if the stock pcv still there
why?
Old Dec 15, 2008 | 03:12 AM
  #92
SgtB's Avatar
The stock and supra valves flow in the same direction. It works perfect.
Old Dec 15, 2008 | 10:48 AM
  #93
Olegator's Avatar
I strongly suggest all of you to read this:
http://www.106rallye.co.uk/members/d...hersystems.pdf
Old Dec 15, 2008 | 11:23 AM
  #94
Opposite_Lock's Avatar
zomg bad link, oleg!
Old Dec 15, 2008 | 02:32 PM
  #95
Olegator's Avatar
http://www.106rallye.co.uk/members/dynofie...thersystems.pdf
Old Dec 15, 2008 | 02:34 PM
  #96
Olegator's Avatar
http://s2000.com/forums/engine-tech-drivet...r-blow-gas.html
Old Dec 15, 2008 | 02:39 PM
  #97
Oleg, I read your post in the crank vents thread. Wouldn't the supra pcv valve keep good flow, while preventing pressure coming from the IM?
I'm planning on putting one Supra PCV valve on the output of the catch can line before the IM.
Old Dec 15, 2008 | 02:42 PM
  #98
Olegator's Avatar
Thats weird, try this
Old Dec 15, 2008 | 02:46 PM
  #99
Olegator's Avatar
It'll probably work even though it is not calibrated for our engines.......plus who said that the stock one doesn't work!? I don't see any reason to change out the stock one if you ask me.
What I will do, after reading the article, is to put in two mall catch cans and see how much oil I'll get.
Old Dec 15, 2008 | 02:59 PM
  #100
Well. the idea is that our stock PCV valves aren't meant for boosted applications. So, we add the supra tt pcv valve to prevent the increased pressure from the IM for FI apps. I guess it becomes more significant as you get higher and higher boost levels.
