Switchable boost levels with AEM EMS
Old Aug 12, 2009 | 09:25 PM
AusS2000's Avatar
Default Switchable boost levels with AEM EMS
I have a GT3071R turbo w/Tial wastegate, AEM EMS with GM boost control solenoid.
I can set the EMS to control the solenoid to cap boost at between 6 (spring) and 23psi.
What I want to know is if I can can two settings (say, 15 and 22psi) and use switch connected to the EMS to trigger the limits.
Anyone know if this is possible?
Old Aug 12, 2009 | 10:43 PM
0piston's Avatar
Yes it is possible, I had had a low and hi boost setting from a simple switch previously on my old AEM
Old Aug 12, 2009 | 10:47 PM
AusS2000's Avatar
Kinda interested in how you set it up.
What were your boost settings? Was low spring?
Old Aug 13, 2009 | 08:04 AM
mikey k's Avatar
Me to!
I could run different octane fuels that way!
Old Aug 13, 2009 | 08:10 AM
camuman's Avatar
friend of mine had a ebc in his car. he ran three boost settings, spring <which was the ebc turned off>, low and hi. can u do something like this in the aem? of can u have a three position switch?
Old Aug 13, 2009 | 08:19 AM
JoeyBalls's Avatar
want to know too, if not im selling my MBC, I want a High,Low, Higher (for meth)
Old Aug 13, 2009 | 09:04 AM
camuman's Avatar
dude 100% u can do this with your ebc. and that would be a sick nasty ride
Old Aug 13, 2009 | 09:05 AM
0piston's Avatar
I had a 1.1 bar spring in a tial 38mm wastegate, hi boost was 1.3 bar and low was 1.1bar and was also running a GM solenoid like yours.
Its been almost 2 years since I converted to Kpro, but I can dig up my old map if you want and can email it to you--just pm me your address. The setup is in there, just can't help you with which PWM output used but its definately possible.
here is a good old link I had that may help
http://forum.aempower.com/forum/inde...c,994.165.html
Cheers,
Joe
Old Aug 13, 2009 | 10:00 AM
2big4aS2000's Avatar
i have set this many times, i would do a waste gate sprint .9 bars for daily driving and then thru the ems, and a switch, goto 20 psi, this way if there is a problem it will default back and wastegate spring will only allow .9 (13.5-14psi) typically on a inline pro log maifold with my modd to a gt35r, daily driven is 400 whp, and a flick of the switch it is 500.
Old May 3, 2011 | 08:04 PM
NS_S2K's Avatar
Sorry to bring this tread back to life. I used the search function before starting a new thread and found this.
I have the AEM Boost Control Solenoid w/ out the gauge along w/ the AEM EMS V2.
My boost is currently controlled by the EMS @ 14psi.
I also want to have a switchable boost level.
From the AEM Boost Control Solenoid in the engine bay I traced the wires thru the firewall and one wire went to the fuse box above the ECU and the other wire went into EMS Connector D16 --- PW 2 Output Avail, Boost Solenoid Output.
If I disconnect that wire does it cut off the Electric Boost Control which is set @ 14psi via EMS and drops the boost down to my 10psi wastegate spring?
If that is the case, do I just wire a switch from that wire so I can make the boost switchable from wastegate 10psi to 14psi?
Also, if possible I want switchable boost levels from wastegate 10 psi / low boost 12 psi / high boost 14 psi. How can I make this possible?
Thanks in advance!
