tapping the girdle
Old Jul 5, 2010 | 12:46 PM
wait4vtec's Avatar
Default tapping the girdle
I tried searching but i did'nt get the awnsers i needed
my drain line is backing up and i want to tap the girdle so i dont have this issue anymore
i NEED any and all info on how to tap the Girdle, and where its even located(lol)
any input i appreciate
Old Jul 5, 2010 | 12:50 PM
dsddcd's Avatar
What are the symtoms that lead you to believing oil is stacking up?
Are you sure you are backing up oil?
Where do you have it tapped now?
I am assuming you are running a turbo so are you running a top, bottom, sidwinder......
What size drain line do you have now?
Have you installed a clear hose on the drian to test?
Old Jul 5, 2010 | 12:59 PM
wait4vtec's Avatar
i have the mase kit and i have it tapped on the passanger side above the oil drain bolt(pretty high up though
car smokes when taking off and coming to a stop
drain line is -10an
what kind of clear hose should i get, when i test with this hose will i use the fittings from my current drain line?
Old Jul 5, 2010 | 02:11 PM
Irishflame27's Avatar
what are you feeding with, any restrictors?
Old Jul 5, 2010 | 02:26 PM
Spoolin's Avatar
This is where you want it per Ultimate Racing. I've had mine this way with a -8 drain line for 7 years with no issues at all.
Also, you can drill it by hand using a large T-handle tap holder but you may have to cut the bit down so it'll be short enough to get it in there or you can get a short shank drill bit. You need to drill a small pilot hole first too and you can also do this by hand. The aluminum is pretty soft so its not hard to drill by hand, just take your time and it'll work.
Old Jul 5, 2010 | 03:27 PM
dsddcd's Avatar
drain line is -10an
I talked to Mase the other day about this after my turbo went out due to other issues. You should give him a ring, recently he used clear tubing on another car with the same issue and they did not stack oil in the drain line meaining that your problem lies in the turbine seal or too much oil pressure.
Which turbo bearing option did you buy?
AlexSobe614
Aug 3, 2016 01:56 PM
Suzuka_Joe
Jun 19, 2013 01:44 PM
seoul2k
Apr 26, 2011 04:40 PM
itlynstalyn
Dec 15, 2010 01:02 PM
Ilike2DRIFT
Aug 24, 2010 10:12 AM
