Thought / question about AEM EMS
Old May 14, 2010 | 05:08 AM
  #21
wadzii's Avatar
Banned
you can use the vtec pressure switch to tell when vtec has been pressureized.
i think its switch 4 .. i dont remember exactly but its in the instructions.
you can tell ls10 (cel) to come on when switch 4 or whatever switch turns on.
if you really want you can also use this to trigger nitrous maps and have a separate map for vtec.
Old May 14, 2010 | 05:16 AM
  #22
Spec_Ops2087's Avatar
stupid question, but how do you actually do that? I'm not the most familiar with the AEM software
Is it in the "configure > outputs" menu? I was looking around, you can also make it so vtec must also be "engaged" for LS10 to ground (turn on). If you did this, I think, that means both the vtec pressure sensor and throttle position / whatever else the EMS looks at must be active for the CEL to turn on to indicated vtec is engaged. Corret me if I'm wrong?
Old May 14, 2010 | 06:49 AM
  #23
wadzii's Avatar
Banned
the vtec pressure switch turns on when the vtec system see's oil pressure.
the vtec pressure switch can not be turned on until after vtec is activated. It takes bout 25-50 rpms for this to happen.. you can actually log it.
you will set this up in configure outputs menu.
goto LS10 in that menu
set the basic activation parameters to greater than the minimum for the setings.
under switched output configure, check active.. then set that to switch #4 gnd=on ( i think its gnd=on, if the cel is on when vtec is not on, then set that to gnd=off)
make sure the functions box is un-checked
Old May 14, 2010 | 07:36 AM
  #24
candymanjl's Avatar
wadzii! whenever I would be on the AEM forums I'd always look for your posts, then I knew I was getting good info!
Old Oct 27, 2010 | 12:49 PM
  #25
s2k.igor's Avatar
is this correct?
I'm not sure about the basic actovation parameters
Flipz
Jul 20, 2016 04:15 AM
s2kseven
Mar 27, 2014 06:29 PM
MB
Jul 12, 2010 01:46 PM
trivium
Aug 28, 2007 06:23 PM
beroznikmal
Oct 8, 2004 12:46 PM
