Thrust bearing failure/Crank walk thread
Old May 16, 2009 | 08:18 AM
  #21
joes sled 2000's Avatar
Originally Posted by Rollinx25,May 16 2009, 11:48 AM
I'm curious now....
For the people that have had this failure. Did you have a fully built motor or was it on a stock motor just adding the turbo setup and different clutch setup?
It has happened to completely stock cars .
Old May 16, 2009 | 08:52 AM
  #22
ThatPreludeGuy's Avatar
I dont believe I've seen any first hand examples, there was one thread however there was later speculation that the motor had been swapped/rebuilt in that car. That was kind of the point of this thread to remove the he said/she said stuff from the other threads.
A poll is not going to answer all the questions that are relevant, I didnt consider it because of that.
Old May 16, 2009 | 11:34 AM
  #23
Ive seen 2 that were both completely stock . The first one had 140k on the clock and was beaten to death ! The second one happened with a BRAND NEW honda shortblock with only 1k ! That particular car got a new engine from the owner running the car out of oil . When i was swapping out the shortblock i tried to get the owner to purchase a new clutch while everything was apart but he said no . The car was pefect with the new engine when it left the dealership . A few weeks go by and the car returns . The owner was stating that the clutch felt weird and it was hard to put into gear . I verified and then discovered that there was crankwalk . I was TOTALLY shocked ! After seeing this with my own 2 eyes makes me know that the clutch is not the single reason as to why this is happening . I would have never believed it if i didnt see it . So when i see these accusations on this site i just laugh ! I think that there is something going on at the assembly plant but thats pure speculation !
Old May 16, 2009 | 11:35 AM
  #24
dstevens's Avatar
We see thrust bearing failures on K20 engines with aftermarket clutches if the clutch interlock is not disabled. Even stock clutches give the thrust bearing trouble. Think about it. The flywheel loading is 800-1200 lbs, and you're turning the engine over when it has zero oil pressure.
Old May 16, 2009 | 11:38 AM
  #25
I think that the clutch interlock thing is a good idea , however i dont think that the clutch interlock is the problem .
Old May 16, 2009 | 12:14 PM
  #26
GrandMasterKhan's Avatar
[QUOTE=ThatPreludeGuy,May 15 2009, 12:06 PM] I
Old May 25, 2009 | 09:02 AM
  #27
P.S.
Happy Memorial Day Guys...
Eat, drink and be merry and remember the boys who made it possible.
1SlowSi
Aug 20, 2013 11:26 AM
vduber
Oct 9, 2012 08:54 PM
bois2k
Apr 17, 2011 07:14 PM
TelosHedge
Jul 8, 2009 06:08 AM
fireman1291
Jun 5, 2006 05:12 PM
