Tial bov
Old Aug 12, 2010 | 09:38 AM
rsmatti's Avatar
yes i was at that site before. but there are people saying its perfectly fine if its open at idle? is this true? will it have any negative effect on the car?
Old Aug 12, 2010 | 10:09 AM
MaseEng Nick's Avatar
its supposed to be open at idle.
/thread
Old Aug 12, 2010 | 10:38 AM
spectacle's Avatar
Originally Posted by wait4vtec,Aug 12 2010, 09:38 AM
How does the the size of the bov spring make a difference to a turbo set up?
The spring determines how responsive the BOV is to changes in vacuum. Here's a breakdown
1. During boost the pressure is equal on both sides of the BOV (charge piping side and top portion of the valve)
2. A vacuum line is hooked into the top of the BOV, this is how pressure is equalized (boost pressure is also seen through vacuum ports, say from the intake manifold where most people reference their BOV line)
3. BUT, with the addition of the spring, the pressure keeping the valve closed (from the top) is boost pressure + whatever the rating of the spring is.
4. Because of the rating of the spring, the vacuum the engine pulls has to be enough to overcome the spring pressure for the characteristics of the BOV to match off throttle events. If the spring is too strong, the motor cannot open the valve on time, causing compressor surge. Too soft a spring will just keep it open whenever you're not in boost. Not much of a problem, except you're letting unfiltered air through the valve into the engine. I think it will adversely affect throttle response as well. Theorectically, you could use a 1psi spring and it would work
Hope that makes sense.
Old Aug 12, 2010 | 10:58 AM
rsmatti's Avatar
well i called tial. they said if vacuum at warmed up idle is between 20-22 i need an 11 pound spring, so Ijust ordered it.
thanks
Old Dec 24, 2010 | 03:19 AM
purekoryo's Avatar
Did the 11 psi spring keep it closed? Do you have any compressor surge? Didyou notice any quicker throttle reponse and quicker spool?
Old Dec 24, 2010 | 07:24 AM
jefferyg32's Avatar
thanks
Did you actually measure Vacuum or were you going off of what they said at Tial? Not ever car reads the same Vacuum. Standard Hondas may run 20-22 but anything could change that. Are you stock motor? Are you low compression? Stock intake manifold and emissions devices? If you changed anything and have not checked what Vacuum your motor is actually pulling, just buying something someone told you might not be the right thing.
The BOV should slightly be open at idle, barely noticeable! Check your Vacuum first and then order. If you need a softer spring then just cut the heavier one!
riceball777
Jul 18, 2012 09:49 AM
Dr Jekyll
Jun 30, 2012 07:29 AM
eastonh477
May 15, 2012 01:01 PM
Fierc3
May 24, 2011 06:55 AM
bumpins2k
Nov 30, 2005 04:47 PM
