tial or syncronic bov?
Old Jan 15, 2008 | 08:16 AM
passmans2kny's Avatar
thanks guys, crap i have the old tial, i think im just gonna get the synaspe and sell my tial, anyone interested pm me, ill hook u up
Old Jan 15, 2008 | 11:46 AM
Tyraid2K's Avatar
synchronic FTW
Old Jan 15, 2008 | 11:47 AM
foxer10's Avatar
Originally Posted by S2KPANG,Jan 14 2008, 08:28 PM
If you're getting surge with the TiAL bov then you don't have the right spring. They just released the new design and is suppose to flow 60% more than the previous.
From my experience, bov's works differently on every car and setup. Some guys dont have problems, some others do. For my S2k setup, I had surge on the tial. There is no question on having the wrong spring rate or if it was installed correctly or not. I had the 11psi spring which is matched with the vacuum the s2k is pulling and the vacuum source was installed properly (cant really mess that up).... On idle, rev'ing the motor, the valve never opened. On the dyno and on the road, on full boost it would surge for a second then blow off. On lower lower boost, throttle let off, the valve wouldnt open. To reduce surge, we installed the 9psi spring. Obviously it would be softer and quicker reacting. It helped a lot but it still surged. Even if flow is better by redesign, that wont fix it from not opening upon initial throttle close. What would help the tial is for it to react instantly and not lag.
Old Jan 24, 2008 | 10:17 AM
D-S2K's Avatar
Originally Posted by Spec_Ops2087,Jan 15 2008, 07:28 AM
Are you able to run a boost controller on their wastegate? I know it has a built in "boost controller" but I need to use an electronic boost controller.
yes, you can run a boost controller with the Synapse wastegate. there's a forum on the Synapse website, which you can see a thread discussing it.
http://synapseengineering.com/smf/index.php?board=3.0
Nippon Power at Miami, Florida has the Synchronic BOV and Wastegates at a good price too. Check them out.
www.nipponpower.com
Old Jan 24, 2008 | 11:56 AM
im gonna try the tial 44mm wastegate, but im def going for the syncronic bov instaed if the tial, anyone running the syncronic wastegate? feedback?
s2k_suprchrgd
Sep 7, 2018 05:56 AM
Hagar
Feb 14, 2014 07:20 PM
Nmatthews2000
Nov 24, 2009 12:28 AM
SHEPSS2K
Oct 2, 2008 05:47 AM
hahnn002
Jul 19, 2006 08:01 PM
