toda cam?
Old Apr 1, 2005 | 05:52 PM
lexar13's Avatar
Default toda cam?
would the Toda Racing Spec A Version 2 Cams do any justice to a turbocharged low compression s2000???
Old Apr 3, 2005 | 04:09 PM
DaveZuck's Avatar
i'm no camshaft expert, but I remember from my front-drive drag racing days that usually the cams that work well on all motor Hondas usually don't work very well on turbocharged engines.
I remember a buddy of mine with a custom T3/T4 setup on a H22A that put some crazy H22A NA VTEC cams on his car and it ran like ass
I remember reading about how good NA VTEC cams have a lot of overlap, which is not something that you want with a turbo because of blowthrough
Old Apr 7, 2005 | 07:23 PM
RZFD's Avatar
Get some adjustable cam gears and you can tune out most of the overlap. I don't how wild the Toda cams are for F20C's though.
Old Apr 8, 2005 | 05:39 AM
VeilsideAP1's Avatar
toda went to the limit with the durration specs, etc. since they were meant to be used in NA engines, I wouldn't think they would be optimal for FI... The stock cams as they sit are pretty good for FI apps if you ask me, but I'm not an engineer...
Old Apr 8, 2005 | 01:34 PM
TECH43 RACING INC.'s Avatar
these guys are right.
too much overlap + boost is a bad combo...you won't hold boost. get the adj gears....and you'll pick up power by spreading the lobe centers
tidus888
Sep 17, 2015 10:35 PM
roadents2k
Jan 13, 2007 02:58 PM
FOSCshadow
Jun 3, 2006 06:42 PM
jlangton
Dec 17, 2002 05:04 PM
Austin_S2000
Nov 29, 2000 07:44 AM
