torque solutions vs. hondata intake manifold gaskets
Old Oct 23, 2015 | 02:41 PM
LiveFast's Avatar
Default torque solutions vs. hondata intake manifold gaskets
Looking into purchasing an intake manifold gasket.
Wanted to know a couple things.
1. Do they do what they claim to do?
2. Do they help with Temps on forced induction setups?
3. How does the Torque Solutions gasket comare to the Hondata gasket?
Any information would be appreciated?
Old Oct 23, 2015 | 02:48 PM
riceball777's Avatar
personally i would just stay stock. I use to run the hondata intake manifold gasket many years ago in my integra days and after a few years my gasket cracked and became very brittle and just gave my nothing but trouble.
Old Oct 25, 2015 | 03:40 PM
camuman's Avatar
I have the hondata gasket. I don't think it's any noticeaable difference. Prolly not wroth it. Def not worth the time and aggravation to install.
Old Oct 25, 2015 | 05:24 PM
joes sled 2000's Avatar
Not worth the trouble at all ! Leave the oem unit in there . I've installed a couple in s2k's and there was no difference at all .
Old Oct 25, 2015 | 05:53 PM
s2000Junky's Avatar
I am running a Blox thermal gasket, same as Hondata but cost a little less. Same material. I have done 2, one wile motor in the car ( total pita!) and last one when engine was out, and the only reason why I decided to do it again. I wouldn't do again if the engine was in the car. But I think like most things bolt on power related, this mod works best with the accompaniment of everything related, such as capping off the coolant at the block so nothing is running through the TB or manifold at all. Then of course having a source of cool/fresh air to the intake with either a snorkel or some other custom cold air intake. These things all together makes a night/day difference on performance I currently enjoy.
Old Oct 25, 2015 | 08:04 PM
LiveFast's Avatar
My head is actually off the car currently so that's why I was looking into it.
You have a link to a writeup on blocking off the coolant to the manifold, throttle body, etc?
I am running K-Pro so I would like to eliminate all unnecessary vacuums, coolant, emission lines, etc...
Old Oct 25, 2015 | 11:40 PM
s2000Junky's Avatar
I dont off hand, but I know if you do a search you will find a few here. Its been done to varying levels by many on this site. Some have done the "ball bearing" version which just blocks the existing coolant host to the TB which is half assed. You want to block off the entire manifold and that can be done by simply blocking the small 3/8" feed hose coming off the top of the thermostat/large upper hose connection under the manifold, which can be easily reached/found with your head off. Just put the appropriate size rubber cap and clamp on the nipple.
Old Oct 26, 2015 | 08:05 AM
LiveFast's Avatar
will do. and def looking into it.
Old Nov 30, 2015 | 03:47 AM
Totalpkg's Avatar
Gizzmo Intake Manifold gasket is by far the best I've tried, and I've tried all of them. Its made of the same material as phelonic spacer that were used on v8's before. No cracking issues and the intake is warm to the touch even with the supercharger fully warm. I've learned my lesson with these heatshield gaskets and always use 2 oem intake manifold gaskets (1 on each side of the heatshield gasket).
http://www.nolimitmotorsport.com/giz...mo-gasket.html
schhim
Mar 8, 2019 11:53 PM
Stine
43
Jul 25, 2016 09:47 AM
B0neSt0ck
Jan 26, 2014 09:43 PM
zerospel
Dec 6, 2006 07:06 AM
s2khondaimport
Jan 6, 2005 07:11 AM
