torque specs for turbo install
Old Jun 23, 2010 | 07:50 AM
Deception's Avatar
Default torque specs for turbo install
Can someone help me out with some info.. In the process of putting my turbo back on the car with new revhard manifold. I had to take a lot of things apart due to clearance issues.
Precision 5857 turbo, rev hard cast log mani
What are the torque specs for...
-4 bolts that go from turbo inlet to manifold (im using stage 8 bolts for this)
-the 6 bolts that hold the center section to the turbine housing
-ARP manifold studs & the nuts
- 5 downpipe flange bolts
thanks in advance
Old Jun 23, 2010 | 08:20 AM
Suzuka_Joe's Avatar
tighten the bolts up and then check again after a few heat cycles
Old Jun 23, 2010 | 08:29 AM
JuicedS2K's Avatar
thanks in advance
I just bolted my 5857 up, i just tightened everything, then tightened again after i few heat cycles, just make them tight man, there is no way of getting a torque wrench on all the manifold studs anyway, your gonna have to get in there with a wrench for some of them.
Old Jun 23, 2010 | 08:38 AM
Deception's Avatar
Yeah I know , just wanted them as a guideline kind of.
Good thing I have skinny arms, it help when contorting in the engine bay
Old Jun 23, 2010 | 10:23 AM
freshs2k's Avatar
I put a little bit of loctite and tighten and let them sit for a few hours before I run the engine.
Old Jun 23, 2010 | 10:31 AM
DFWs2k's Avatar
damn i need to check mine
Old Jun 23, 2010 | 11:01 AM
Mrfixit687's Avatar
Hows the clearance on the 5857 with the revhard manifold? How close is it to the frame rail? Can anybody post up a pic of their setup and what oil filter relocation you guys are using with it?
Old Jun 23, 2010 | 11:33 AM
Deception's Avatar
I will take some pics when its all back together... the turbo fits fine, about 3/8"-1/2" clearance from the frame rail. I run an ETD just to be safe.
Im running the canton oil relocator, its a very tight fit. I need to grind it down more because the shop that installed did not, it was touching the turbo when everything was together
Old Jun 23, 2010 | 12:24 PM
Mrfixit687's Avatar
Can you tell me the specs of your turbo deception?
S2kserry
Aug 31, 2014 06:43 PM
rikhemi
Aug 14, 2012 06:58 AM
jtins2k
Dec 16, 2011 12:00 PM
H4RD ON
Feb 22, 2011 02:49 PM
ChefJ
Jun 20, 2007 06:08 PM
