Track days while supercharged - Questions
Old Sep 23, 2015 | 12:29 PM
APoner's Avatar
I would definitely invest in an oil cooler. NA s2000's run with very hot oil temps on track and they dont have the added stress of the blower. If you are going on track with a supercharger i would use an oil cooler and at least an upgraded radiator and heat ex-changer. Either wont hinder any performance and can be had fairly inexpensive.
Old Sep 24, 2015 | 07:02 AM
hvAlfaWant_S2000's Avatar
I run a Vortech S/C at 13-14 PSI and only have the SOS heat exchanger with the Bosch pump. Stock rad and oil cooler. Ran 3 20 min sessions at a HPDE this year and zero heating issues. My brakes got pretty hot though!
Old Sep 24, 2015 | 08:04 AM
s2000Junky's Avatar
Risky on the main part of that, which is your oil. As mentioned oil temps have proven to run very hot on this car N/A on track, so to not even have one Sc is temping fate. At the very least it will increase engine wear rate, and at most cause a catastrophic failure at some point.
Old Sep 24, 2015 | 02:14 PM
Dizings2k's Avatar
So to get this straight... as long as I keep the oil within acceptable temp range, I don't have to worry about spinning a bearing or things of that nature?
Old Sep 24, 2015 | 04:15 PM
s2000Junky's Avatar
No, you shouldn't. Your covering your bases with the oil temp/cooler, coolant temp/larger radiator, and AIT/larger racing heat exchanger. If you want to take it one last step further, you can do the vent mod to your hood or buy a vented hood for track days to help evacuate engine heat. Not required, but shown to be beneficial and work.
radiantm3
Jan 29, 2017 01:31 PM
Mike's
Aug 2, 2016 04:44 AM
Redline S2K
Oct 20, 2014 11:40 AM
Sebring AP1
Jul 2, 2013 06:31 PM
Ztec
Jun 21, 2005 11:37 AM
