Traction
Old Aug 4, 2010 | 01:56 PM
  #31
Spoolin's Avatar
Originally Posted by jaundice,Aug 4 2010, 12:19 PM
I had my fenders rolled by a local club member for $50. He also relocated the bumper tab. Absolutely easy. Took him 2 hours and no rubbing issues.
What is this bumper tap you guys are talking about?
Old Aug 4, 2010 | 07:26 PM
  #32
StaticS2K's Avatar
What is the biggest/widest tire anyone has stuffed on stock rims?? Just curious cuz I have a extra set of rear wheels for drag tires. : )
Old Aug 4, 2010 | 08:44 PM
  #33
s2000Junky's Avatar
I would say 255 for ap1 and 275 for ap2
Old Aug 4, 2010 | 08:55 PM
  #34
juntuned's Avatar
With a wide enough wheel/tire set up you will rub the bolt (front side bolt nearest the fender on the rear bumper) the bolt is moved back about an inch or two to be pushed out of the way of the tire, also so it can be tightened. New holes are drilled etc.
Old Aug 4, 2010 | 11:03 PM
  #35
Spoolin's Avatar
Hmmm.....I run a 18x10 rear rim and 275/35/18 BFG DR's but it doesnt seem to rub that screw. The only part it sometimes rubs is the inner lip of bumper plastic and I just let it rub to open up a spot for the tire. I'll look at mine again but i dont think that screw is in my way.
Old Aug 5, 2010 | 04:30 AM
  #36
ap1tuner's Avatar
Originally Posted by camuman,Aug 4 2010, 08:07 AM
what offset? did you roll and relocate?
No I didn't do anything with it yet. The body hasn't been touched. It just went right on and barely cleared
Old Aug 5, 2010 | 08:10 AM
  #37
s2000Junky's Avatar
Surprising with that wheel size, but you might just be getting past it for various reasons, such as high enough wheel offset- Wheel alignment- Limited susp compression over bumps. If your tire is stretched on the rim somewhat, you might be tucking in just past it under compression.
Old Aug 5, 2010 | 09:05 AM
  #38
Spoolin's Avatar
I guess it has to do with the offset being setup correctly, I dont know.
They are custom iForged rims and the offset was set up the best way according to them. I have a 2" lip on the rears and 1" on the fronts that are 18x8.5. On the rears, there is only about 1/2" of space between the inner tub and inner tire. My 275/35's are rougly 11" wide and my rear rims are 10" wide, so no possible tire stretch at all. My alignment is setup so I get the highest possible contact patch on the ground, even when it squats. If I remember correctly, 2 deg of rear camber is the least I could go with mine being lowered about an inch with the Eibach Pro springs.
Old Aug 5, 2010 | 10:21 AM
  #39
s2000Junky's Avatar
Sounds like a nice set up
Still a little skimpy in back for my taste though
Old Aug 5, 2010 | 10:38 AM
  #40
o'malley_808's Avatar
Advan AD08's are garbage for anything but track, I have 265's on my car and they dont even squeal on 100 degree days. They are way too hard of a compound for hooking up on the street...
