transmission strength
Old Mar 16, 2009 | 10:34 AM
ctb2024's Avatar
what size gear we talking though with nissan and toyota--are they near the 4.11 stock size (i think that's stock for the s2k)??
Old Mar 16, 2009 | 12:38 PM
AndyFloyd's Avatar
you could make a lot of tranny's fit with custom adapter plates.
Old Mar 16, 2009 | 01:02 PM
phils2k's Avatar
these are the price list i received from ppg in November. the prices are in AUS $ so roughly converts to 3600 USD
Honda S2000 6spd helical (synchro)
$5,500
3.16 / 2.09 / 1.53 / 1.22 / 1.04 / 0.88
selectors = NO
Direct fit - no mods needed
Honda S2000 6spd helical (dog box)
$9,350
selectors = NO
Old Mar 16, 2009 | 01:57 PM
honda9krpm's Avatar
I think you are confusing between gearbox and diff ratio. The s2k oem diff ratio is 4.1:1. Nissan has a couple of variable to this. I think I have a 4.37:1 ratio (or somewhere around there) in my nissan diff.
Old Mar 16, 2009 | 02:00 PM
honda9krpm's Avatar
It will be good if someone can come up with an adaptor plate for a supra box. There are so many of them around and they are mighty strong. Not only that they are so cheap. If any gearbox part fail you just get a reconditioned box and slap it back in. If ppg part breaks
Old Mar 16, 2009 | 02:19 PM
Tyraid2K's Avatar
Originally Posted by honda9krpm,Mar 16 2009, 05:48 AM
I have a nissan skyline r33 gearbox in mine everything seems to fit into the stock location. I just needed to modify the bellhouse, mount, custom flywheel and a custom driveshaft.
pics or this is a lie
Old Mar 16, 2009 | 03:43 PM
honda9krpm's Avatar
No prob buddy
The car is on a hoist at home atm because I have to change the gearbox mount. The gearbox had a modified honda gbox mount and there was too much movement. I found it difficult to shift gear quickly between 1st and 2nd. It has dog helical gears so the timing for shifting is crucial.
So pics shouldn't be any problem. Do you have any specific angle you like to see?
I actually had this for 5 years aldready. I am surprise that no one else has investigate something like this....actually I saw ?c-west put the same gearbox in the S2k about 3-4 years ago. Their is a sequential though.
Old Mar 17, 2009 | 03:43 AM
honda9krpm's Avatar
As promised,
Sorry the car is a bit messy atm as I just installed the new engine and still have a bit more TLCs to do. The dogbox is fun to drive but that's about it. It's a chore and expensive to maintain. If you don't have access to a hoist, don't get one.
Old Jan 28, 2010 | 07:05 PM
mdrob_79's Avatar
Dude, I can not believe I've just found this post now! And that no one replied!
Nice trans conversion indeed.
I so need a better box as I keep killing the bearings on the output shaft of the standard s2k box. That happens at 400rwhp I guess
Was finding a clutch disk to fit an issue?
Did you need to shorten or mod the tail shaft?
Oh and does the shifter hole line up?
Any help would be awesome.
Thanks
Old Jan 29, 2010 | 04:31 PM
btstone84's Avatar
i broke that piece of shit ppg tranny. i hated it
