Trying to keep a/c cool
Old Apr 28, 2014 | 05:26 AM
Sylvain2000's Avatar
Originally Posted by APoner
I thought it was... Exchanger, condensor, radiator. Flow going -->
Hence I thought of adding a fan in front of the condenser to emulate the car moving
I maybe wrong
Im no engineer but i dont think that another set of fans ( extra one in front of the condenser ) is A good idea.
I think its gonna add restriction when cruising. " maybe " even screw the flow for the oem fans.
But like i said ... I cant proove my theory
Old Apr 28, 2014 | 06:12 AM
camuman's Avatar
Originally Posted by Redline S2K
What kind of fans do you have Camuman?
drivers side is the stock fan. the passenger side fan is some bobo one off summit racing that fit between teh radiator and the turbo piping. fans are set up thorugh aem to turn on all the time. they dont cycle.
Old Apr 28, 2014 | 06:35 AM
APoner's Avatar
mine are set up to cycle. And come on with the a/c just like stock.
Im going to evac my system in the next couple of days and see if i was low on freon and properly fill it to spec. (although i think my a/c is just fine)
I might just have to add higher flowing fans. To over come the restriction of the heat exchanger.
Old Apr 28, 2014 | 06:45 AM
Redline S2K's Avatar
I'm thinking about running one Spal 12 inch extreme fan on the drivers side and a 11 inch slim on the passenger side as it's more cramped from the turbo.
Not a bad idea to check just to eliminate that from the equation or possible problems.
Old Apr 28, 2014 | 07:53 AM
yamahaSHO's Avatar
You could just top of the system yourself to see if that fixes the issue. I'm betting that's all it needs and you'll be back to cold AC all the time.
Old Apr 29, 2014 | 07:48 AM
RAIN H8R's Avatar
Before you dump any time and money into fans, confirm the setting in the aem. Then have the ac system checked.
I had an identical problem years ago with aem. A shop confirmed the pressure was fine in the ac system but it was not flowing well. I changed the cheaper item which was the valve near the battery but it ended up being the ac compressor had failed.
Sent from my Samsung Galaxy S4
Old Apr 29, 2014 | 10:09 AM
james0933's Avatar
Adding fans will not help. Have the sytem checked professionally. They can verify the pressures and determine the root cause. If needed, they can easily find the leaks and recharge the system. They will also verify your refrigeranf contents to be certain it is 100% r135a.
If you insist, you can rent the gauges yourself at autozone or the like. Do not charge the system with anything other than pure r134a.
Old Apr 29, 2014 | 10:45 AM
They could've know the ac compressor was bad when they checked pressures unless they just evacuated the system and refilled to spec.
Sent from my SM-G900P using Tapatalk
Old Apr 29, 2014 | 11:30 AM
APoner's Avatar
Im leaning towards something in the a/c system not being in spec either.
Old Apr 29, 2014 | 02:44 PM
RAIN H8R's Avatar
Huh? We did evacuate the system. We tested as much as we could and found either valve or comprrssor was bad. I did the valve first which didnt fix the issue. Then i did the compressor and that fixed the issue
