Trying to make DIY oil filter relocator
Old Apr 11, 2012 | 04:10 PM
H4RD ON's Avatar
Default Trying to make DIY oil filter relocator
Trying to use this kit:
http://www.autopartswarehouse.com/de...e&apwidAza9heF
but can't get the Honda 90015-PH1-013 oil adaptor to screw in the block at ALL!!! The threads are perfect and the factory one goes in like butter. ????
What is going on? Anyone else run into this problem? I have multiple 90015-PH1-013's brand new out of the package and all won't screw in at all.
Old Apr 11, 2012 | 09:49 PM
jefferyg32's Avatar
They are different threads on each end maybe try flipping it over?
Make sure you didnt bugger the threads from trying to install it different times and didnt mess anything up when taking the old one out. When i did mineit was a little harsh going in but was able to thread inmost of the way by hand and then used the adapter to screw it in the rest of the way.
Old Apr 12, 2012 | 02:08 AM
Leviisbigred's Avatar
are you using your oil cooler>? did you take it off?
Old Apr 12, 2012 | 04:20 AM
H4RD ON's Avatar
Yea, different sizes but even my GF couldn't mistake the 2 lol And I haven't messed up the threads on either pieces but I feel like if i force this piece in then I will. Steel vs. aluminum, the block would lose. Thats why it doesn't make sense that the stock one goes on absolutely no problem with finger all the way. Its almost as soon as the other piece starts to turn its gets tight. And like I said I have multiple little fittings brand new so it's not like I just got a weird one or something.
No lol ....no way you could use the fitting with the oil cooler. Also, have a Kings Performance sidewinder so room is very limited.
Old Apr 12, 2012 | 06:00 AM
Phill24's Avatar
if ur relocating ur filter u could take the piece the filter screws on to, to get taped for the oem bolt and use the oil cooler..if u need pics of it done i'll post 1 up
take ur oem bolt and the replacement one and match them up together make sure the thread pitch is the same
Old Apr 12, 2012 | 07:46 PM
dsddcd's Avatar
I have built several and created a DIY a while back (See my Sig). I would HIGHLY recomend that you high quality proven parts, personally I would not trust that kit and stick with quality hoses, fittings..... Secondly you need to ensure that you hook everything up correctly failure to pay attention here and you will be buying a new motor.
https://www.s2ki.com/s2000/topic/828...elocation-kit/
Old Apr 13, 2012 | 03:33 AM
when i used mine. i got the fitting off a D series block.. now i have a sindwinder but it doesint come close to it at all. i have the fitting and the better oil rec if you wana talk
jpetch05
Feb 8, 2013 06:14 PM
bruce0293
Jun 11, 2009 12:21 PM
skool u
Mar 16, 2009 01:16 PM
dsddcd
Sep 27, 2008 08:57 PM
hpark
Nov 21, 2004 04:23 PM
