Tstat / Headstuds / HG
Old Nov 10, 2012 | 05:48 AM
OHclassic's Avatar
Default Tstat / Headstuds / HG
Been checking out various threads on here for over 2 hrs with varying info...hoping some of you might be able to answer on one thread for me:
GTX-3076 R @ 18psi => 500WHP / 356 TQ
93 Oct w/ 50% methanol injection
** ALL OEM Block/head
1.) Thermostat - OEM best replace ? What's the average TIME to replace with nothing else removed ?
2.) Headstuds - Do I need at 18psi and 500whp or am I OK with stock OEM bolts ? I don't want to open the head unless theres a reason. $$
3.) HG - OEM stock thickness seems the consensis....Honda or aftermarket ?
Thanks ! />
Old Nov 10, 2012 | 08:18 AM
s2knoob89's Avatar
Stock unopened block for anything under 600whp. 18psi is alot for pump gas and I wouldn't reccomend it unless you have lowered the compression ratio.
14psi seems to be the most common stopping point for pump gas.
Old Nov 10, 2012 | 08:28 AM
OHclassic's Avatar
OK - Forgot to mention 93 Oct w/ 50% methanol inj.....
Old Nov 11, 2012 | 05:59 AM
OHclassic's Avatar
Help !?!?!? Consideration / replies please !
Old Nov 11, 2012 | 07:29 AM
s2knoob89's Avatar
18 psi on meth and 93 is no problem. You'll be fine.
Old Nov 11, 2012 | 12:35 PM
sohc_mshue's Avatar
Keep it all stock. You will be fine.
Old Nov 11, 2012 | 12:57 PM
OHclassic's Avatar
OK thanks, sounds like I DO NOT need headstuds unless others give me some reason why I would but it sounds like stock is cool. />
* Now, car was running HOT (4-5 bars/no aftermarket gauges) and thermostat was stuck closed so OEM replacement on Monday should fix that problem. Going to run a compression test just to make sure everything is OK. Car doesn't have 500 miles on it with turbo so I don't think head or HG could be failing after such short time and hopefully that's the case !
* How long time to fix a thermostat ?
* How long to run a compression test ?
Thanks all !! />
Old Nov 12, 2012 | 05:56 AM
OHclassic's Avatar
Originally Posted by OHclassic
OK thanks, sounds like I DO NOT need headstuds unless others give me some reason why I would but it sounds like stock is cool. />/>
Thanks all !! />/> />
wochi
Oct 15, 2015 09:05 AM
AKs2dope
Jul 3, 2015 04:56 AM
nipponS2000
Aug 23, 2012 04:09 AM
buzz944
Jun 21, 2012 02:35 PM
