DBW F22C rebuild
Old May 23, 2015 | 02:36 PM
AKs2dope's Avatar
Default DBW F22C rebuild
My car recently gave up on me, and its boosted.
Im asking for a better option for me under $1700 budget
Inlinepro offers a FRM piston and im wondering if people here have use them?
My cylinders are ok to bore for 87 x 0.5 pistons
the setup that im thinking is:
Block:
Inlinepro FRM piston 87.05 (10:1)
ACL race bearings
OEM Connecting Rods
stock FRM sleeve bore 87.05
Head:
Inlinepro TCT
ARP Head studs
OEM Head Gasket
BC Dual valve springs/retainers
OEM valve
Did anyone here had a good success on stock Sleeve rebuild?
Old May 23, 2015 | 02:42 PM
JUSTINTHECOASTIE's Avatar
I as well as many trust InlinePro's engine builder, however, check out wadzii (jason) as he has a F24c stroker short block program that is taking off
Old May 23, 2015 | 05:26 PM
riceball777's Avatar
i'm pretty sure you cant use aftermarket frm pistons with stock rods. You will need aftermarket rods.
Old May 23, 2015 | 05:52 PM
AKs2dope's Avatar
I emailed Inlinepro about it, and they said they can make their FRM piston to work with OEM Rods.
Old Jul 2, 2015 | 02:41 AM
S2k_Alaska's Avatar
This is correct, unless you have the pins coated with a special coating(whatever is called) like the oem pins have, but it's suppose to be spendy.
Old Jul 3, 2015 | 04:56 AM
You can use aftermarket frm pistons with stock rods, stock rods will have to be bushed though
02_s2k
Jul 19, 2014 11:26 AM
youngkilla
Jun 8, 2014 07:43 PM
VTECSTYLE
Jun 8, 2011 06:56 AM
exodusx7x
21
Dec 6, 2010 01:31 PM
03S2KAY
24
Nov 8, 2004 11:27 AM
