turbo ap2 s2000
Old Mar 20, 2013 | 10:18 AM
CardsL1C4's Avatar
Default turbo ap2 s2000
so i finally got to installing my turbo kit on last week and noticed there was smoking everytime the car got warm only at idle. it seems to be coming out of the exhaust and its oil burning. I took off a piece of intercooler piping to see if there was any oil and didnt see anything. not sure if its a bad turbo seal or too much oil pressure? any advise on other ways to check if its the turbo seal or not ? thanks in advance
Old Mar 20, 2013 | 08:56 PM
HoustonNFR's Avatar
What kind of turbo are you using? Have you done a compression test? Where do you have oil feeding the turbo from?
Old Mar 21, 2013 | 03:11 AM
bj@jjautowerks's Avatar
What oil are you using?
Old Mar 21, 2013 | 04:58 AM
CardsL1C4's Avatar
I sprayed down the car yesterday and noticed little oil in the exhaust, I'm running a 50 trim Turbonetics and currently using 5w30 valvoline max life I usually run mobile 1 but they were out when I went to buy it
Old Mar 21, 2013 | 07:07 AM
jordannn93's Avatar
5w30 is thin for turbo or sc applications I think
Old Mar 21, 2013 | 04:17 PM
CatsS2000's Avatar
Use regular 10 40
Old Mar 22, 2013 | 08:37 AM
SlosIIk's Avatar
i had that issue only at idle on a precision journal bearing turbo. it would smoke only at idle, the fix was i bought a nitrous jet fitting, .65 and it cleared that problem up quick. and turbo never had issues for the next year until i grenaded engine and pieces of valves destroyed it, wich had nothing to do with restrictor.
Old Mar 22, 2013 | 09:26 AM
CardsL1C4's Avatar
Thanks guys I raised the car on a lift and noticed the return line wasnt on all the way and little oil was escaping, and it wouldn't stay tight it would keep sliding off. Ima replace it and see what happens
Forcedbird
Aug 3, 2015 04:27 PM
DFWs2k
May 19, 2010 08:06 AM
NFRTurboTerror
Jan 20, 2009 07:49 PM
2QYK4U
Dec 6, 2006 06:54 PM
