Which turbo is better?
Old Mar 9, 2016 | 08:05 AM
  #21
JuicedS2K's Avatar
First s2k turbo build 5 years was a "budget build". Lets just say I will never do that again. Saving up an extra few thousand would be my advice.
Old Mar 9, 2016 | 08:27 AM
  #22
liquidgsr's Avatar
You can find a t3 divided Borg Warner. That is what I have. A s262 divided t3 turbo.
Old Mar 9, 2016 | 08:52 AM
  #23
5thgen's Avatar
If you are still looking at the turbo in your original post, I would make sure it would fit.
The turbine to center section look like they can only be clocked every 90 degrees.
Old Mar 9, 2016 | 09:00 AM
  #24
TUKES2k's Avatar
Originally Posted by baZurk
Yes, a t4 twin scroll is less restrictive and gives you a lot more turbo options suitable to the s2000
Idk I kinda feel like t3 has more options.. and plus to run a full twinscroll setup is kinda pricey for a 500 ish rpm spool difference ... just my opinion
Old Mar 9, 2016 | 09:10 AM
  #25
s2000Junky's Avatar
Originally Posted by Alexander Startsev
But what s with spool time/low rpm boost?
Doesnt twin scroll give you pros here?
If i can double torque in 4-7k rpm range i couldnt care less if it dies at 8.5
Sounds like you should be shopping for a Greddy Turbo kit But you wont double the engine trq at any rpm with a Turbo that peaks at 350whp.
Old Mar 9, 2016 | 09:40 AM
  #26
baZurk's Avatar
I agree, I don't think the benefits of a twin scroll outweigh the extra cost, materials, weight etc, but that is for the OP to decide on what he wants to do.
Old Mar 9, 2016 | 10:18 AM
  #27
Alexander Startsev's Avatar
Yes i wanted twin scroll for spooling faster, but ppl say it wont work well for t3 application. Why are they even making t3 twin scrolls then? Maybe it isnt good for 500+ whp but all right for 400-?
Old Mar 9, 2016 | 10:55 AM
  #28
Jin_SK's Avatar
You can get T3 twin scroll turbos, but they typically have small A/Rs. Fast spool, but die up top. You can make it work, but realistically a T4 turbo/manifold will be much better.
And for the love of god, if there's one thing you shouldn't cheap out on it's the turbo. I understand wanting to stay within a certain budget, but I can almost guarantee at the end you'll be more out of pocket than if you had just saved up more money up front and done it all right once.
Old Mar 10, 2016 | 05:59 AM
  #29
For plm t3 header is there a point to put twin scroll t4 s200sx or better go for single scroll t3 gt30xx?
Old Mar 10, 2016 | 06:50 AM
  #30
baZurk's Avatar
You can't put a t4 turbo on a t3 manifold, and vice versa
