Turbo build break in?
So I was wondering, what's the best way to break in a new motor as far as getting it tuned and making sure I don't mess up my new engine when I get this bobo car back?
Engine specs:
ACL bearings
Inline Pro rods
Pistons: I don't remember if they are CP but 11:1 stock compression.
ARP Head studs
Darton Sleeves
Supertech valve springs
Supertech titanium retainers
Valves are stock
Cams are stock
Clutch is the same CC twin disc with CC flywheel I had before
Turbo kit is same as before
Kings V2 sidewinder
Borgwarner S262 comp r ett
Tial 44mm wastegate
Tial 50mm BOV
2.5" IC pipes
Blah blah...all the other crap.
AEM v2
Flex fuel sensor add on
Fullblown complete fuel system
Dual hanger with 2x 340s
I was thinking of running 10psi low boost 15psi high boost. Then later getting the high switching to the higher boost setting I had before 22psi to max it out since I tried that once already in my previous build thread and maxed the turbo out.
Engine specs:
ACL bearings
Inline Pro rods
ARP Head studs
Darton Sleeves
Valves are stock
Cams are stock
Kings V2 sidewinder
Tial 44mm wastegate
Tial 50mm BOV
2.5" IC pipes
AEM v2
Just dont beat the balls off it and you will be fine. Ive had some top tuners tell me the rings seat like 90% in the first 20 mins worth of run time. Everybodies got there own method but there definitely isnt x amount of miles you have to put on it. I finally got my built motor back in my car and ive been driving around about 600 miles mainly cause ive been waiting for some turbo parts or the damn thing woulda been boosted a while ago. Run it enough that you feel comfortable that the motors 100% with no leaks or burning any fluids. My .02
-chris
-chris
Last benson built block. We put on dyno tuner ran it for about 30mins. Few low rpm pulls then few up high. Drained oil and balls to the wall after that... never had a issue with that setup broke in two like that now. After I get the s2000 block built I will do the same on this one too.
Sent from my SPH-L710 using Tapatalk 4
slicknick
16
Dec 12, 2006 12:05 PM
No really I would do what the shop that is doing the build tells you to do. The last build I did I had about 1000 miles I think before I could go wide open throttle on it.
