Turbo Cams
Old Dec 11, 2011 | 06:53 AM
  #61
Thunder-rush's Avatar
Originally Posted by YuriArts
Originally Posted by DFWs2k' timestamp='1323397544' post='21222544
so power also comes on about 500 rpms sooner?
Yep, that's right
Originally Posted by camuman
so your stock cam vs bc sage 2 turbo cam runs where at same timing and boost, just adjusted fuel to get same afr?
Same boost level, adjusted fuel to get same afr. We were also able to run 1 point more timing with these cams over the whole range as well. So that helps ofcourse.
More timing on the stock cams didn't make any difference, on these it did.
Talking about timing and I know every engine is different and trying not to go off topic. Do you guys think running more than 20deg timing up top in pump gas is too much?
Old Dec 11, 2011 | 07:58 AM
  #62
YuriArts's Avatar
Totally depends on your setup and boost level. I think we run 19 degrees at 9000 rpm at 0.9 bar, 15 degrees at 1.2 and 12 degrees at 1.5 bar.
Depends on so much things, type of fuel is very important factor ofcourse.
On the dyno we tested alot of timings at every boost level and rpm to get the max power. At a certain point you see more timing doesn't result in more power. Then you've achieved the max for that setup.
Old Dec 12, 2011 | 07:07 AM
  #63
Thanks! Hope to see you posting track #'s soon.
Old Dec 12, 2011 | 07:39 AM
  #64
benw.17's Avatar
looks good for the BC stage 2 turbo cams do you need to get adjustable cam gears to run them
Old Dec 12, 2011 | 01:45 PM
  #65
YuriArts's Avatar
No you don't.
Old Jun 6, 2012 | 02:22 PM
  #66
"SpoonFedS2k"'s Avatar
Yes updates???
I'm looking at buying a set of Brian's crower cams but wasn't sure on turbo or NA cams. Also oem valves ok?
I have Brian's valves and retainers but stock valves and seats.
Old Jun 7, 2012 | 02:17 PM
  #67
SLINKYDOG's Avatar
a different set-up i know, but some info for the supercharger guys,
i tried turbo cams for my kraftwerks supercharger and lost 3 rwhp, put the stock cams back in and got 4 rwhp back, the 3 rwhp i lost and 1 freebe.
Old Jun 7, 2012 | 07:10 PM
  #68
redboost10's Avatar
I'm using prayoonto stage 3 cams
Old Jun 8, 2012 | 04:41 PM
  #69
vduber's Avatar
What gains have you seen red boost? I have fully built top and bottom end I can spin the motor to 10k easy but stock cams don't make much power for how much stress is on them after like 9500 wanna see what type of gains you got
-Chris
Old Aug 14, 2012 | 03:47 PM
  #70
YuriArts's Avatar
Has anyone else got results with the BC stage 2 turbo cams ??
Would be nice to see others try them as well and have the same results
