Turbo Help
Old Aug 28, 2007 | 05:29 PM
S2kEdm's Avatar
Default Turbo Help
My turbo i believe is making a metal on metal sound instead of boosting the way it should i was driving everything was fine and all of a sudden i get a metal on metal rubbing sound like something was being dragged on the concrete. And the is a whistling sound coming from under the chasis where my down pipe is any one have a idea whats wrong any help would be awsome i am scared my bearings are fried?
Old Aug 28, 2007 | 05:44 PM
ChefJ's Avatar
It could just be rubbing somewhere. Does it do it when you are turning and accelerating during turns: left, right?? Mine rubs when I make hard left turns as the motor is being shifted to the right.
Old Aug 28, 2007 | 05:48 PM
S2kEdm's Avatar
No its when am driving straight and around 3 k rpm is when it gets really loud sounds like the bearings arent being lubricated or something :s
Old Aug 28, 2007 | 06:29 PM
S2kEdm's Avatar
Anyone with any ideas? with my luck my turbo bearings are shot :S
Old Aug 28, 2007 | 06:31 PM
Spec_Ops2087's Avatar
Probably a loose bolt or something. Get under the car and check it out.
Old Aug 28, 2007 | 07:36 PM
S2kEdm's Avatar
I drove it angain and when bost is suppose to hit and i let of i dont hear a Bov sound just the mechanical concrete dragging and the turbo is spinning really load as if its all crapped out
Old Aug 28, 2007 | 08:46 PM
AusS2000's Avatar
Can you edit your title? It says nothing about your problem.
Something like: "Scraping noise from turbo"
Old Aug 28, 2007 | 09:35 PM
As I said check your bolts, specifically the ones holding the wastegate...
Old Aug 29, 2007 | 08:01 AM
S2kEdm's Avatar
Ok ill check all my connections again today i am hoping that it will solve my problem
blueap2
Jan 18, 2009 03:26 PM
ChefJ
Jun 24, 2007 07:28 PM
koji187
Apr 27, 2006 09:56 PM
S2kRob
Dec 17, 2004 09:55 AM
