Weird noise from turbo
Old Jan 11, 2009 | 10:03 PM
blueap2's Avatar
Default Weird noise from turbo
I just installed my turbo again....this time however, I'm getting a wierd noise it idle. It does not sound like metal against metal so I know there is no shaft play, the turbo is pretty new anyway so that can't be it. It's sort of a deep humming sound, when I slightly rev the engine and let it go back to idle it does this then once it stabalizes at idle it goes away....
Hopefully this isn't too confusing....let me know if you have any ideas. Thanks!
Old Jan 18, 2009 | 11:45 AM
Vinsfeld's Avatar
My turbo make a wierd humming sound usually 10 minutes after hitting three bars on temperature gauge. I just assumed this is normal when the turbo itself is fully heated up.
Old Jan 18, 2009 | 01:09 PM
03silver2000's Avatar
are you talking about compressor surge? you rev your motor, and on the motors way back to low rpms(idle) it makes the noise. Check your bov is tight. It sounds like you have comp. surge, and vinsfeld I have no idea.
Old Jan 18, 2009 | 02:29 PM
blueap2's Avatar
does the compressor surge sound come directly from compressor housing of the turbo? thats where i pinpointed the sound from and it only happens after the car is warm likevinsfeld said...
Old Jan 18, 2009 | 03:05 PM
well, compressor surge is when you rev your motor up and the revs drop back down its not all the air is getting released by the bov causes the turbo to want to spin back the opp. direction.
Old Jan 18, 2009 | 03:13 PM
blueap2's Avatar
yeah this is not compressor surge....its a weird hum...could it be possible that its coming from the recirculated dumptube? the dumptube was welded right after the turbo exhaust housing into the downpipe
Old Jan 18, 2009 | 03:26 PM
can you make a video clip of it and put it on youtube or post it on here?
Chance S2K
Nov 4, 2015 03:10 AM
S2kEdm
Aug 29, 2007 08:01 AM
Blackie
Aug 16, 2007 05:11 AM
macprotege5
Apr 8, 2007 10:08 AM
koji187
Apr 27, 2006 09:56 PM
