Turbo Install
Old Aug 27, 2005 | 08:08 AM
slamar1's Avatar
Default Turbo Install
I am preparing for a Turbo install. In doing some research, I found this thread:
https://www.s2ki.com/forums/index.php?showtopic=293423
Is tapping the pan an acceptable way of intalling the return line vs. tapping the girdle? I guess tapping the girdle is the way to do it, but is the pan high enough to not cause any problems? I assume so as this is the way fperra and Tinker do theirs.
Any thoughts?
I would much rather tap the pan
Old Aug 27, 2005 | 08:33 AM
kane.s2k's Avatar
Just tap it as high up as you can in the pan.
Old Aug 27, 2005 | 09:18 AM
slamar1's Avatar
High on the pil pan... got it.
Would you recommend the same fittings at fperra: http://www.amstreetrod.com/984404ERL.php4
I dont have my kit yet, I am just preparing for it so I don't have all the specs on sizes. What size 45* and straight fitting will I need? I am getting the InlinePro kit
Old Aug 27, 2005 | 09:48 AM
fperra's Avatar
Any thoughts?
Actually on my current turbo setup I tapped the girdle. However, when I had the Ultimate Racing setup I tapped the oil pan and experienced no problems.
Old Aug 27, 2005 | 09:51 AM
fperra's Avatar
Get the 1/2 inch pipe thread fitting. And its best to have it welded to the pan, although tapping and a lot of Hondabond will work.
Old Aug 27, 2005 | 09:56 AM
slamar1's Avatar
Thanks, fperra
Was there an easy method of getting at the girdle? I did look down there and it looks pretty tight for getting a dril down there.
Old Aug 27, 2005 | 10:00 AM
fperra's Avatar
No easy method that I'm aware of. My current setup is a fully built engine. I installed the fitting in the girdle when the block was out of the car.
Old Aug 27, 2005 | 10:39 AM
slamar1's Avatar
Gotcha... that would be the easy way to tap the girdle - Yank the motor! plenty of room to get at it that way.
I will tap the oil pan with the 1/2 thread fitting
Thanks for your help
Uzidoesit
Jul 17, 2012 12:15 PM
t0m
Sep 29, 2010 05:07 PM
beb
Mar 16, 2008 04:57 PM
Mike@9k
Apr 30, 2005 06:43 AM
