Turbo not spinning while car is idling
Old Sep 17, 2016 | 06:57 AM
AlexSobe614's Avatar
Default Turbo not spinning while car is idling
Sorry for the frequent posts here - it's my first turbo build and I am pretty new to all this. So I started my car for the first time yesterday and found my turbo doesn't spin while the car is idling? I know the turbo spins freely and it is a fresh rebuild. Plus I know he turbo is getting enough oil. It's a turbonetics t3/t4b if it helps. Thanks guys
Old Sep 17, 2016 | 07:14 AM
NWDyno's Avatar
That's normal...might start to spin at idle once it gets a few miles and loosens up.
Old Sep 17, 2016 | 07:19 AM
Thanks, I did some reading online and all I really found were a bunch of people arguing over that.
Old Sep 19, 2016 | 12:45 PM
sdosmil77's Avatar
check for exhaust leak by turbo area if still no spin
Old Sep 19, 2016 | 06:57 PM
spectacle's Avatar
Something definitely wrong.
Old Sep 19, 2016 | 07:23 PM
Why do you say that? Because it spins freely while outside the car...
Old Sep 21, 2016 | 06:39 AM
Hershey's Avatar
I had 4 different turbo before and they all spin on start up and idle. Did you clocked the turbo and maybe just offset it wrong where it touches the housing?
Old Sep 21, 2016 | 06:52 AM
TerminatioN's Avatar
Not necessarily saying there is a problem but just because the turbo "spins freely while outside the car" doesn't mean there isn't a problem. As someone mentioned there might be an exhaust leak or another plumbing problem. There is much more to the equation than just the turbo.
Old Sep 22, 2016 | 05:54 AM
spectacle's Avatar
Because I've never heard of or seen a turbo that doesn't spin at idle. It's like asking if you're supposed to feel air coming out of your exhaust when the car is running.
Old Oct 2, 2016 | 02:56 AM
timg's Avatar
Generally, ball bearing turbos spin at idle. Older journal bearing turbos often do not. Some larger ball bearing turbos may not spin, but this is unlikely and could be a sign of damaged bearings.
Tim
steamedturtle
Hard at Work
36
Apr 8, 2013 11:23 AM
