Turbo question
Old Feb 11, 2008 | 06:04 PM
  #21
afwfjustin's Avatar
Originally Posted by Spec_Ops2087,Feb 11 2008, 09:45 PM
Vented hood helps and is the easiest thing to do. Other things would be radiator, oil cooler, etc but I think thats overdoing it for a street driven car.
Also I can speak for justin, but its becoming known that the AEM CAL tables for coolant are off by about 15-20 degrees so if he hasn't updated them, his temps were fine
Oh wow - I had no idea about the aem tables. I'm sure that they wouldn't have been calibrated so maybe I really am fine...
Typically my car runs at 190 degrees.
Old Feb 11, 2008 | 06:05 PM
  #22
BoostedK's Avatar
I havn't updated my cal table either. Is it really necessary spec? O_O
Old Feb 11, 2008 | 06:22 PM
  #23
s.hasan546's Avatar
what would be the best radiator to get to get the most cooling? (regardless of price).
Old Feb 11, 2008 | 07:14 PM
  #24
Spec_Ops2087's Avatar
I'd stick to whatever is in your system now as certain parts of your tune (cold start) I believe is based off of what the coolant temperature is.
It shouldn't be necessary, just be aware that your numbers might be off by a few degrees on the hot side which I guess is better then being too cold
Old Feb 11, 2008 | 07:15 PM
  #25
Koyo makes a nice radiator and for relativily cheap
Old Feb 11, 2008 | 08:21 PM
  #26
s.hasan546's Avatar
would installing a koyo radiator even b4 i put in the turbo help me at all?
Old Feb 11, 2008 | 10:24 PM
  #27
for a stock car, no.
Old Feb 12, 2008 | 05:24 AM
  #28
devs2k's Avatar
the fan switch for MY06+ is different than MY05 and prior. The fan switch was replaced by a second coolant temperature sender. You need to modify the any aftermarket radiator a bit to get the temp sender to fit properly in place of the fan switch.
vbb
Feb 29, 2012 07:54 AM
phinancer
Oct 15, 2011 09:50 AM
autoxgti983
Oct 28, 2009 07:14 AM
f20cpower3
Jun 23, 2008 12:07 PM
vvs
Jul 28, 2004 09:14 AM
