Turbo setup advice
Originally Posted by JoeyBalls,Apr 8 2009, 10:07 AM
If you cant afford the GREDDY KIT, you simply wont be able to piece together a similar kit for lower............., Just save the money and do it right.
dude if u cant afford a greddy kit (ive seen used for 2-3k with the EMU and everything) than you cant afford to go FI with your S. Its the cheapest turbo solution for our car. u might be able to piece together a cheaper kit but itll be all crap items. dont spend like an idiot and save up and by a bolt on kit. most people who go with custom kits do it for huge power. and even they say its a hassle to get every part to work with each other.
https://www.s2ki.com/forums/index.php?showtopic=687695
2500 for a complete kit; only 7k on the greddy kit
Originally Posted by nsxnext,Apr 8 2009, 12:15 PM
I always thought the Greddy kit was expensive as well.
However, the used greddy kits are a basement bargain!
280-300 HP will NOT be enough. You say it will be now but it simply will not be. Trust me I know.
Also if going FI and you plan on spending only 2-3 grand, be sure to have an extra 2-3 grand for all the things you will buy soon after.
Originally Posted by P-CarDriver,Apr 8 2009, 04:49 AM
1)Would a T3/T4 be okay for 300whp?
2)At 7psi making 280-300 what size injectors would i need?
3)Would the stock fuel pump be enough?
4)E-manage Blue enough for smooth idling and tuning or should i get Ultimate.
2) i would say somewhere around 550 or so. there is no reason not to go a bit bigger, however.
3) no. you could probably get away with it, but why risk it?
4) i would actually recommend the FIC over the emanage ultimate, unless you have a very reputable emanage tuner in your area. in the case of EMB vs EMU, go with the EMU.
if you are looking for cheap parts, i've got some
Originally Posted by DFWs2k,Apr 8 2009, 02:37 PM
why FIC over EMU?
Maybe the FIC isn't like this?
Originally Posted by DFWs2k,Apr 8 2009, 03:57 PM
I've read of more problems with the FIC, I didn't even know the s2000 was fully functional yet...
At least with the EMU you can research and be aware of the known issues...
Happy EMU user here
