Turbo and stock compression
Old Sep 3, 2007 | 08:35 PM
TheCarGuy2021's Avatar
Default Turbo and stock compression
Well, I'm most likely going to be making the switch from the Vortech to a GT35R setup within a few weeks. I'm not going to be putting on a 3mm inlinepro head gasket for a while. I know the S/C can "generally" have a little more boost on stock compression than a turbo (~12psi max for S/C) due to not being fully boosted at lower rpm. Question is until I get a 3mm head gasket, what would be sufficient? I still would like to make some decent power and was thinking of getting it tuned somewhere in the ballpark of 8-9psi. Does this sound safe?
Old Sep 3, 2007 | 08:39 PM
Ty.'s Avatar
Ty.
I ran 7.5psi for over 65k miles (~300whp on a small'ish turbo) with no problems at all
Old Sep 3, 2007 | 09:04 PM
afwfjustin's Avatar
What kit are you going with? You could get around 400 whp on a Lovefab kit at 9 or 10 psi. Just have your tuner keep the timing back some.
Old Sep 4, 2007 | 05:20 AM
GT1 manifold, GT35R.
Old Sep 4, 2007 | 05:59 PM
minitoyota's Avatar
I've run 10psi on my gt1 mani, gt3071r, for a couple months now with no major problems. Its really all about the tune and how much you trust your tuner's ability.
Old Sep 4, 2007 | 06:13 PM
How much power did you make minitoyota?
Old Sep 4, 2007 | 06:52 PM
minitoyota's Avatar
375whp at 7psi and 425whp at 10psi
Old Sep 4, 2007 | 06:55 PM
Thanks!
Old Sep 5, 2007 | 04:38 AM
minitoyota's Avatar
No problem. I was going to do the 3mm HG as well but I was more then happy with the power it made at 10psi, I decided to hold off till this winter and build the motor instead.
Old Sep 5, 2007 | 10:55 AM
afwfjustin's Avatar
Lovefab owns
gdmlaz
Feb 23, 2008 12:32 AM
s2guru
Mar 26, 2007 09:12 PM
05s2kStreet
Oct 5, 2006 01:05 PM
WtbS2k
Jun 10, 2006 10:33 PM
timg
Nov 30, 2004 02:38 AM
