Turbo with Vortech after cooler
Old Jul 25, 2006 | 03:40 PM
JDM S2000's Avatar
Banned
Default Turbo with Vortech after cooler
Anyone ever think something like this would work out?
Instead of having a front mount, just have the air to water cooler.
Old Jul 25, 2006 | 05:26 PM
Slows2k's Avatar
AW aftercoolers can be used on a turbo, but they will need to be larger than the Vortech supplied unit, as well as a larger heat exchanger, and pump.
Old Jul 25, 2006 | 07:04 PM
JDM S2000's Avatar
Banned
So something like this wont work?
Old Jul 25, 2006 | 07:15 PM
Slows2k's Avatar
It CAN work, but the aftercooler needs to be sized properly to the turbo, as well as the heat exchanger and pump for the aftercooler system. IIRC, the PWR's are not as efficient as some others, mainly a Laminova.
The only other short term benefit to a AW aftercooler is the ability to briefy cool the intake charge to below ambient temp by using iced water in the system. After the ice melts the fun is over though.
Old Jul 25, 2006 | 07:22 PM
JDM S2000's Avatar
Banned
Hmmm
Well Id like to turbo my car but I do not want a front mount on it.
Old Jul 25, 2006 | 07:23 PM
XclusiveAutosports's Avatar
Just curious, but why would you want to use this instead of a FMIC? Just seems like you are re-inventing the wheel.
Old Jul 25, 2006 | 07:32 PM
Slows2k's Avatar
Laminova's are very efficient, and worth investigating. Or you could use a V-mounted air to air intercooler.
Old Jul 25, 2006 | 08:32 PM
wannabuy's Avatar
Just hard anodize the intercooler black. Hence if stealthy is what you want. Worked on my car perfectly.
-Chris
DRUNKS2K
Aug 11, 2010 06:51 PM
VTECSTYLE
Jul 2, 2010 11:22 PM
A .
Jun 17, 2008 11:07 PM
batikan
Aug 11, 2007 08:39 PM
AndyS2
Sep 26, 2003 09:26 AM
