View Poll Results: Turbo or Supercharging?
Turbocharging
62.96%
Supercharging
37.04%
Voters: 27. You may not vote on this poll
Turbocharging or Supercharging the S?
Old Oct 29, 2006 | 09:03 PM
GyozA's Avatar
Default Turbocharging or Supercharging the S?
I'm Just curious. I want Horsepower gains in the 400. I've had different ppl say each one, but none of them actually owned an S2k so I decided to get on here and ask around. Thanks In Advance.
Old Oct 29, 2006 | 09:53 PM
WolfInSheepsClothing's Avatar
400whp more than stock? or just 400whp? You could get to 400whp with either a turbo or a supercharger (horsepower will be very peaky with a centrifugal s/c though).
Old Oct 30, 2006 | 12:31 PM
Reborn56's Avatar
Turbo
Old Oct 30, 2006 | 12:53 PM
XclusiveAutosports's Avatar
The powerband in a turbo setup can't be beat, but the question is how often do you like to work on your car?
Old Oct 30, 2006 | 01:48 PM
TRBOKEV's Avatar
Do you want to go the smog legal calmer route or the all out balls to the walls route?
Old Oct 30, 2006 | 04:41 PM
gt30r's Avatar
How much are you willing to spend? Turbo, is not cheap
Old Oct 30, 2006 | 08:38 PM
Birdie's Avatar
Turbo is much more efficient then a supercharge, and yes you need alot of money on the side just incase anything were to happend. This is way I purchase an EVO because the engine is capable of handling 500whp without any problems with all the supporting modification.
But a built s2000 engine with turbo would be insane =)
Old Oct 30, 2006 | 09:58 PM
GyozA's Avatar
I'm taking out a 15k loan and putting money into the turbo first. Then I go from there. I plan on doing internal work but I would really like to keep the budget for the engine work at 9k. Right now I'm thinking InlinePRO with the AEM EMS w/U band and most of the options.
Old Oct 30, 2006 | 10:06 PM
kane.s2k's Avatar
It's more expensive to put an S/C into the 400whp mark at this point
Old Oct 31, 2006 | 05:16 AM
S2000_Europe's Avatar
Turbo has better power band but is harder to tune than SC. I am not sure if SC is more expensive at the 400 WHP in both case you will need to build the engine if you want to have a wider safe margin
J
S2K_Ownz
Oct 30, 2002 06:12 PM
