Turnng up the Boost, need some help
Well im finnaly turning up the boost i went and bought a 2mm head gasket from Cometic....
basically im new to turbo cars in general, and the question i need help with is do i need to change my wastegate spring in order to achieve higher boost if i have a boost controller?
I bought the turbo XS Dual stage boost controller, and a tial 38 mm wastegate that has a .5 bar spring in it, would i need to change it if i wanna run say 12 - 15 lbs.? and where would i get the spring from, directly from Tial?
Thanx Any help will be much appreciated!
I see you are from Michigan, where did you get it tuned at? I am looking for a good tuner near by. I origanally got tuned at tunning factory in Farmington Hills but I think Cody's street tune is a lot better.
Thanx for the help!
I went to The Tuning Factory also, I think the tune wasnt that great cuz i get some blips in the power at around 3000-4000 RPM, but the A/F's are fine. I need to get it tuned by cody or mabye get Payne to Tune it.....Im gonna wait till i get some more parts for the fuel lines though before retuning it....which means stock boost for a little while longer.
I had another question, if any one knows....when i ordered my gasket i told the lady a 2mm head gasket, she gave me the part number so i ordered it. when i recieved it, its .030", i thought a 2mm is .07", am i wrong or do i have the right part?
Any help would be great!
Thanx
Thanx
Charper732
May 21, 2017 07:14 PM
s2kdan05ems
Mar 17, 2011 09:34 AM
