Twin scroll or single?
Old Oct 4, 2012 | 01:40 PM
AWWHITE s2k's Avatar
Default Twin scroll or single?
What is the difference..
Old Oct 4, 2012 | 01:49 PM
sata3000's Avatar
Twin uses 2 wastegates which i believe allows for a slightly quicker spool. I could be wrong please correct me if i am
Sent from my Galaxy S II using Tapatalk
Old Oct 4, 2012 | 01:55 PM
JoeyBalls's Avatar
It's really just divided or undivided, not really a "twin" scroll, I like my divided, gives me nice mid range and a lot of trq, if you want big big numbers,moron not a good idea
Old Oct 4, 2012 | 02:01 PM
baZurk's Avatar
They way i understood it there was two scrolls that expell the exhaust at two different angles into the turbo housing that allows the turbo to spool quicker.
Old Oct 4, 2012 | 02:17 PM
passmans2kny's Avatar
About Twin Scroll: Twin Scroll turbo system design addresses many of the shortcomings of single scroll turbo systems by separating those cylinders whose exhaust gas pulses interfere with each other. Similar in concept to pairing cylinders on race headers for N/A engines, twin scroll design pairs cylinders to one side of the turbine inlet so that the kinetic energy from the exhaust gases is recovered more efficiently by the turbine. For example, if a four-cylinder engine's firing sequence is 1-3-4-2, cylinder 1 is ending its expansion stroke and opening its exhaust valves while cylinder 2 still has its exhaust valves open (while in its overlap period, where both the intake and exhaust valves are partially open at the same time). In a single scroll AKA undivided manifold, the exhaust gas pressure pulse from cylinder 1 is therefore going to interfere with cylinder 2's ability to expel its exhaust gases, rather than delivering it undisturbed to the turbo's turbine the way a twin scroll system allows.
The result of the superior scavenging effect from a twin scroll design is better pressure distribution in the exhaust ports and more efficient delivery of exhaust gas energy to the turbocharger's turbine. This in turn allows greater valve overlap, resulting in an improved quality and quantity of the air charge entering each cylinder. In fact, with more valve overlap, the scavenging effect of the exhaust flow can literally draw more air in on the intake side while drawing out the last of the low-pressure exhaust gases, helping pack each cylinder with a denser and purer air charge. As we all know, a denser and purer air charge means stronger combustion and more power... but the benefits of twin scroll design don't end there. With its greater volumetric efficiency and stronger scavenging effect, higher ignition delay can be used, which helps keep peak combustion temperature in the cylinders down. Since cooler cylinder temperatures and lower exhaust gas temperatures allows for a leaner air/fuel ratio, twin scroll turbo design has been shown to increase turbine efficiency by 7-8 percent (faster spool, quicker response) and result in fuel efficiency improvements as high as 5 percent. It is wise to size the turbine housing A/R larger than the single scroll turbine A/R typically used!
Old Oct 4, 2012 | 02:19 PM
Hmm I'd like to keep my single gt motoring exhaust. My tuner/installer tryed telling me to get a non twin scroll. So I wanted to kno y not. I'm only looking for around 380whp on a 5858
Old Oct 4, 2012 | 02:25 PM
Ok I was gonna run a full AFI turbo kit with a 5858 turbo and 1000cc injectors aem v2 Ems. I'd use a twin scroll if I did not have to cut my fender/hood to make a exhaust port. Btw my engine bay is fully tucked in shaved
Old Oct 4, 2012 | 11:44 PM
Corey Maurer's Avatar
Why would you have to cut anything? You can use the same exhaust.. Lol
Old Oct 5, 2012 | 04:12 AM
Bc every1 I seam to talk to crys about the back pressure from making the dump tubes longer. They clame the shorter the dump tubes the better
Old Oct 5, 2012 | 05:06 AM
umm, no
