Twin scroll or single?
Old Oct 5, 2012 | 07:06 AM
AWWHITE s2k's Avatar
Ok so I'll ask 10psi is it better to have 1 waste gate or 2 it's not like I'm pushing massive power like 23psi at 609whp
Old Oct 5, 2012 | 07:29 AM
passmans2kny's Avatar
for your power goals thw twin scroll set up is a waste, hell even the equal length manifold is a waste if you only want 380hp, just get a log and keep it simple
Old Oct 5, 2012 | 07:43 AM
baZurk's Avatar
Old Oct 5, 2012 | 08:50 AM
ScorpionT's Avatar
Depends on the turbo size. If you have a big turbo and want to run 10psi, two wastegates will work better. If you have a small turbo and run 23psi, one wastegate will work better. Its just a matter of how much exhaust energy you want to divert away from the turbo.
A twin scroll manifold isnt really necessary, but I always prefer equal length for efficiency reasons.
Old Oct 5, 2012 | 08:59 AM
vduber's Avatar
Bc every1 I seam to talk to crys about the back pressure from making the dump tubes longer. They clame the shorter the dump tubes the better
You really need to start conversating with more intelligent people
Old Oct 5, 2012 | 10:20 AM
Phill24's Avatar
Lol i think thats why he made a post to conversate with intelligent people
Old Oct 5, 2012 | 11:00 AM
^^^ I'm all ears I'm here to learn in build a turbo setup that's gonna last not blow. Ill be running a 5858 63a/r 10psi I'm guessing sidewinder single wastegate AFI full turbo kit with 1000cc injectors. As of up the spark . What's good affordable coil packs/ spark plugs
Old Oct 5, 2012 | 11:08 AM
Reapur's Avatar
Keep the OEM coil packs and use NGK bkr8eix plugs gapped correctly.
Old Oct 5, 2012 | 11:12 AM
Corey Maurer's Avatar
If your goal is a measly 300 don't waste your money on a side winder
Old Oct 5, 2012 | 11:43 AM
that turbo on a sidewinder is gonna make like low 400s @ 10 psi
