ultimate emanage on the s2k w/ vortech
Originally Posted by Dsgs2k3,Sep 4 2006, 12:26 AM
you need to get an AEM EMS to run 750cc injectors. the stock ecu wont be able work with them. pretty sure that 550cc injectors are the limit on stock ecu
. Before you post
in reply to someone asking for advice make sure you've got your facts straight, or you're just adding to the confusion. The most the stock ecu can handle are the injectors the car came with from the factory. Regarding the 550cc injectors, many believe that 550cc is the maximum the emanage blue will run, as greddy states that the blue can handle up to 150% larger injectors. Chitah831 seems to have proved them wrong though
. As for the larger injectors, there are a number of forum members that have used 750cc with the ultimate emanage.
