The Ultimate Emanage Thread
Originally Posted by deppenma,Jul 25 2006, 07:32 PM
As to why JP8 and be set at either the 5V ignition output or the 12V ignition output and the system/car still works is not fully understood.
If the JP is left open there would be no ignition output to the coils from the ULT
JP8 routs then ignition output through either a 12v circuit or passes it through a voltage reducer to bring it down to 5V
One should use the 5V setting.
If you are going to use the ULT's features for speed adjusted maps and/ or the speed/Odometer adjustment for different gears/larger or smaller OD rim/tire packages; the ULT VSS interface must be wired in at the same location where the Yellow box does its thing. Not at the Stock ECU like boomslang or the ULT installation manual states.
This info is unconfirmed at this time but it makes since to integrate the VSS wire this way.
I am considering putting it back in.
It is still sitting on the my desk as a paper weight right now since I have not heard back from evasive.
I was not planning on using the VSS options anyways just was passing on that info for any one that might still want to use it.
I just don
I just don
Originally Posted by deppenma,Jul 25 2006, 10:58 PM
For a add/trim setup like mine
If the JP is left open there would be no ignition output to the coils.
Since the ULT is in line in this case.
If you going to use the system to add only I am not sure since the ULT tags are only taped in.
You want to use the 5v setting . This is only the trigger to the coil and not the output . This is why both settings work . The coils will not like it for long as the extra voltage will create heat and possibly short them out over time .
Add/trim feature only apply's to the Injectors and has nothing to do with the ignition .
I got all the screen shots done . I will try to post everything tonight
humm just had a thought.
What about leaving JP8 in the 12V position with a separate CD ignition system(MDS or similar) tagged to the factory Molex plugs at the valve cover and run an aftermarket coil and spark plug setup.
Not really require to up grade the ignition system until somewhere around 600hp but may be goods for a few more hp...
What about leaving JP8 in the 12V position with a separate CD ignition system(MDS or similar) tagged to the factory Molex plugs at the valve cover and run an aftermarket coil and spark plug setup. o
To answer some of your other question . Logging timing has no point . If you are tuning on a dyno you log the Knock and set timing accordingly
what the final number is irrelevant as you can not use the same timing for someone else .
W/I IAT tag for an additional protection from high intake temps causing pre-ignition
W/I Greddy load based activation for pre-ignition/knock/increased power during normal boosted condition above 4to 5 psi.
(Looking at the BRP hot side roots high boost setup 8psi and maybe more at later date with an AEM Rising fuel pressure regulator and the Greddy controlling the injectors for boost under 8psi with an upgrade to the fuel pump when going over 8 psi.
For those that did get it to work on a N/A application did you input the cc of the injectors and what lag time did you enter?
As far as triggering the Water injection , I have not tried to do anything like that on the e-manage . I see why you would want to with the BRP charger if it is non intercooled . If it does have a intercooler there is no need .
No where the hell is my Lunch
I need to get back to work .
It will depend on the coil that you would be using . It is only a trigger as I said and not the output for the coil . .
what the final number is irrelevant as you can not use the same timing for some one else ..
The ULT does not have a knock input but I have seen on another distributors web site that there is a possibility of a knock monitoring data logging coming with a future software update. (future connection through the option ports on the unit.) I think I saw an option in the program for a knock sensor input I will need to look at it again tonight.
Would be nice if it was possible to interface this option port to the factory knock sensor.
[QUOTE] The AEM regulator is fine if you want to upgrade and only raise fuel pressure 1psi for 1psi of boost.
