The Ultimate Emanage Thread
Originally Posted by tomh,Jul 31 2007, 11:24 AM
it is and emanage blue. please send me a PM if you can help
http://search.yahoo.com/search?p=greddy+em...op=mss&ei=UTF-8
Looks like MOHD is down - you can get it from Greddy also.
http://www.trust-power.com/03electric/emanage.html
Originally Posted by tomh,Jul 31 2007, 11:48 AM
tried that
Originally Posted by Twiztid,Jul 31 2007, 12:15 PM
Originally Posted by WLAURENT,Jul 31 2007, 03:50 PM
Thanks T - he was looking for the blue version.
Thats what happens when I rush around the shop then sit for a minute browsing forums , I always miss something
Wish I could help you with the A/F target map , But we dont tune anything using that method . I have ben using the subinjector outputs for the last two jobs , 350z and G35 and they work great
Originally Posted by Twiztid,Jul 31 2007, 12:56 PM
Sorry , my bad .
Currently using the IAT adjustment map to compensate for temperature swings - almost have it dialed in, just need to wait until it cools off a bit more to make sure I am good on the lower temp ranges.
Pretty cool injector mounts in that picture - did you guys fab that up?
Played around with the Knock sensor input a little more and could not get it to read anything of value. I am guessing that the circuitry on the board is just not sensitive enough to pick anything up without picking up everything. I am fortunate to have 110F temps this time of the year - it is no challenge to get audible knock from a boosted car - tried every freq - resonant and non-resonant
I tried a device call knocksense- http://www.viatrack.ca/
The initial results were promising. I could detect (and correct by pulling timing) knock below VTEC. Unfortunately once in VTEC there was obviously too much noise for the simple filters on the knocksense device to filter out valve noise from knock. Of course it could have been my eaton supercharger making the extra noise, but the factory ECU does not read it as knock (as it is not pulling timing).
Unless Greddy comes out with a new firmware with better filters, I am not thinking this will be a useable feature. I am working with an analog card to analyze the knock signal to see if there is a simple filter that can be used to ID knock from the OWM sensor.
Originally Posted by scareyourpassenger,May 17 2007, 09:17 PM
These are the jumper settings used on the Greddy turbo kit for those that want Greddy confirmation.
JP1 open
JP2 open
JP3 Open
JP4 open
JP5 open
JP6 open
JP7 1-2
JP8 2-3
JP9 Open
JP10 2-3
JP11 Open
JP12 Open
JP13 Open
JP14 Open
JP15 1-2
JP16 1-2
JP17 open
JP18 open
JP19 1-2
JP20 1-2
JP1 open
JP2 open
JP3 Open
JP4 open
JP5 open
JP6 open
JP7 1-2
JP8 2-3
JP9 Open
JP10 2-3
JP11 Open
JP12 Open
JP13 Open
JP14 Open
JP15 1-2
JP16 1-2
JP17 open
JP18 open
JP19 1-2
JP20 1-2
