Ultimate Racing Turbo install PROBLEMS!
Old Apr 1, 2005 | 05:38 PM
FullEffect256's Avatar
Default Ultimate Racing Turbo install PROBLEMS!
The output on the turbo(that goes to intercooler) that came with the kit is facing the passenger side frame and will not allow the turbo to fit.... it seems as tho the output is supposed to drop down to connect to the intercooler piping... any ideas?.. if i unbolt the turbo i think i can turn it to where it's suppsoed to be and then bolt it back right... what do you think? thanks!
Old Apr 1, 2005 | 10:05 PM
jareds2k's Avatar
that is right you can unbolt the turbo and turn it were you need it
Old Apr 2, 2005 | 12:35 PM
fperra's Avatar
Post a picture, it would help. From your description, I think all you have to do is clock the compressor housing. In any case, when you need technical help, call Ultimate Racing. Their customer support is excellent.
Old Apr 2, 2005 | 07:58 PM
RT's Avatar
RT
loosen the six bolts on the comp housing and reclock but make sure you don't clock it so far that the oil feed line goes too far under the heat sheild or that won't fit.
Old Apr 3, 2005 | 03:01 PM
NightStalker's Avatar
just what they say, unbolt and turn it. I did the exact same thing when i did my kit. My friend caught it and its a pain b/c i had to unbolt exhasut manifold etc... to get it out, but it works.
rikhemi
Oct 12, 2010 03:11 AM
TelosHedge
Oct 22, 2008 12:02 PM
atlxkevinx
Apr 2, 2008 10:34 PM
jdnissanz
Dec 15, 2006 11:57 PM
massimos
Jul 31, 2004 05:43 AM
