Inline Pro GT30 Turbo Install
Old Oct 11, 2010 | 05:29 PM
rikhemi's Avatar
Default Inline Pro GT30 Turbo Install
Might be installing the turbo with my friend and had a couple of questions. I heard the hardest part of a turbo install is tapping the oil pan. Since I already have one tapped, is the rest pretty straight foward?
Also, do you need to lift the engine to get the turbo in with the inline pro kit, gt30 size turbo?
Is there anything difficult or hard in regards to the install? Dont want any suprises.
Thanks for any help.
Old Oct 11, 2010 | 05:47 PM
s2k dre's Avatar
No need to lift the engine, everything will fit good. And tapping the pan is the easiest out of the whole install.
Old Oct 11, 2010 | 05:50 PM
rikhemi's Avatar
If tapping is the easist, what is the hardest? heard that the bolts for the manifold need to be extra tight since they have a tendacy of coming loose.
Old Oct 11, 2010 | 05:53 PM
s2k dre's Avatar
To fit the turbo and mani and to tighten the bolts is the most time consuming. And fitting the intercooler and stuff like that. First u have to figure out if u can fit the turbo and mani as one piece or u have to put it in seperately.
Old Oct 11, 2010 | 08:00 PM
dsddcd's Avatar
Read some of the build threads and you will see what you have to do.
I have one you can get through on my sig also check for Revenge and Trbokev's
Old Oct 12, 2010 | 03:11 AM
rikhemi's Avatar
Great info. Thanks.
So how long do you think this takes? I was going to take a day off work and start at 8am.
boostovereverything
Mar 8, 2012 12:33 PM
///MFreak
Jul 19, 2011 03:18 PM
EPM04
Jun 30, 2010 05:07 PM
sbrodacz
Mar 3, 2009 09:48 PM
slamar1
Aug 27, 2005 10:39 AM
