ultimate T3/T04E Turbo
Old Sep 8, 2006 | 06:16 PM
S_NeWb's Avatar
Thumbs down ultimate T3/T04E Turbo
hi i am running:
greddy e management
440cc
spugen v2 ti catback
took it to dyno and results was not very pleasing.
it runs good for couples of runs then it drop 70 hp, the it jump back up.
real bad hestiation.
just to keep it runnin right timing is -18 degree
one moment is running good and other is bad. i am new to FI and pouring out a lot of money already.
is it the turbo? tuning?
i've talked to kane.s2k he say its the greddy management and he recommend aem ems 1052 and i would love to get that. but money is not right now. is there anything i can do?
thx for the help
Old Sep 8, 2006 | 07:16 PM
Slows2k's Avatar
Posting a dyno sheet and your e-manage settings may help.
Old Sep 8, 2006 | 07:25 PM
S_NeWb's Avatar
y my Dumb azz forgot the dyno sheet at the shop and cant get it until monday
Old Sep 9, 2006 | 08:42 PM
PSPS2K's Avatar
Do you have a wide band Air/Fuel Guage? If you do, does it bounce around lean and rich?
Old Sep 10, 2006 | 05:12 AM
timg's Avatar
If you have knock, the stock ECU could definitely retard enough timing and add enough fuel to lose 70 horsepower. Honestly, it doesn't sound like a very safe tune. That's the problem with piggybacks, they're incredibly difficult to get dialed in correctly. You really need to scan the stock compter while tuning the piggyback. You cannot just tune the piggyback without plugging into the ECU. By the time you buy a scanner, WBO2, and the piggyback, you will have spent about as much money as if you had just bought an EMS.
Tim
Old Sep 10, 2006 | 10:39 AM
kane.s2k's Avatar
He doesn't have a very good tune at all as a matter of fact some parts have 18 degrees of retard I believe if I remember correctly. However he's also complainning about the car having hiccups occationally which is all too common with most people running the e-manage.
Old Sep 10, 2006 | 06:29 PM
Chitah831's Avatar
No hiccups here
Everyone's different. Took me almost 2 years to figure mine out. But boy am I happy now
Old Sep 13, 2006 | 10:51 AM
efinguy85's Avatar
greddy e-01's r painsss not sure how much u know about the system but here is a little guide to helped me. maybe this can get you in the right direction?
SET This is how you set the boost pressure. Rather than setting it in psi or kPa, the Greddy unit allows you to adjust it as a percentage value, from 0% (greddy unit essentially turned off) to 100% (greddy unit will set the boost as high as it can). This setup demands a certain amount of trial-and-error to properly configure it since you have to make adjustments, then drive under WOT (Wide Open Throttle) and see what the maximum boost pressure achieved was throughout the entire RPM range. SET SHOULD BE SET TO A CONSERVATIVE VALUE WHEN BEGINNING TO TUNE YOUR GREDDY UNIT. 30% SEEMS TO BE A CONSERVATIVE SETTING BASED ON MY TESTING AND BASED ON OTHER REPORTED NUMBERS FROM EVO OWNERS AND TAKING INTO CONSIDERATION THE LINK BETWEEN SET AND GAIN (see GAIN below).
GAIN is defined in the manual as the value to adjust the "boost consistency". You don't really need to know exactly what that means. You should set GAIN to 0 when beginning, and you will then test the car under WOT while paying attention to the boost pressure. If the boost goes up and then falls off at higher RPM, you will want to increase the GAIN by a conservative amount (5% should be relatively conservative to begin with, then when you want to fine-tune it, you can go down to intervals of 1%). When you increase the GAIN value, the corresponding boost that you will go up to will be higher even if you leave the SET value alone. GAIN SHOULD BE SET TO 0 WHEN BEGINNING TO TUNE YOUR GREDDY UNIT.
START BOOST (also known as SET GAIN because that is what is displayed on the unit when adjusting this setting) is the lowest boost that the Greddy unit will begin increasing the boost from under WOT. You want this to be as close to the SET value as possible, since you want to keep as close to your desired boost as possible. However, setting it too close to the SET value will cause the boost to spike. You should set this to a conservative setting when beginning to tune your Greddy unit. Then you can fine-tune it later to get it as close to the SET value as possible without causing the boost to spike. Fortunately, you can set this in psi or kPa, thankfully Greddy didn't decide to let this be adjustable in % like the SET value. START BOOST SHOULD BE SET TO YOUR DESIRED BOOST PRESSURE MINUS 4 PSI (about 28 kPa).
WARNING is the maximum boost that you do not want to exceed. Fortunately, you can also set this in psi or kPa like the START BOOST value. When the boost exceeds the WARNING level, it will kick in the LIMITER, which decreases the boost a certain amount that you can set. WARNING SHOULD BE SET TO YOUR DESIRED BOOST PRESSURE PLUS 1 PSI (about 7 kPa).
LIMITER is the boost percentage that the Greddy unit will lower to when the WARNING boost pressure is hit. LIMITER SHOULD BE SET TO YOUR SET VALUE MINUS 4%.
PEAK is the peak boost value that the unit has seen since the last time it was cleared. To clear it, go to the peak boost display, and hold down the set knob until the unit beeps and "---" is displayed. IT IS A GOOD IDEA TO CLEAR THIS BEFORE YOU BEGIN JUST IN CASE YOUR UNIT HAS A HIGH BOOST ALREADY RECORDED.
LAST BOOST shows you the last boost that was recorded every time the accelerator is released for 3 seconds. TURN LAST BOOST ON BECAUSE IT IS A GOOD DIAGNOSTIC TOOL WHEN TUNING YOUR UNIT.
Keep in mind that when displaying in kPa, it does not show it technically in kPa, but rather misleadingly in bars, which Greddy inconveniently tries to justify by sticking x100 kPa next to the display. Therefore, 100 kPa will be displayed as 1.00 x100 kPa. Psi will also unfortunately be displayed in psi x10 so that 19 psi will show as 190, adding to the confusion.
Another very important thing to keep in mind is that when you first power on your car or the Greddy unit, WARNING will be set to 14.5 psi (100kPa, or 1 bar) until you interact with the Greddy unit by pressing any button. This "feature" is not documented in the manual.
Also keep in mind that atmospheric conditions affect the operation of your boost controller. When it is hot, you will get different results than when it is cold. One possible way of solving this issue is tuning your Greddy unit under the "Lo" mode for when it is relatively cold, and under the "High" mode for when it is relatively hot. Unfortunately, two modes are hardly enough for somebody that needs to account for very different summer and winter climates, and also for more aggressive settings for when increased performance is desired.
The maximum boost that you will see is also not consistent throughout the gears, which adds even more to the confusion. Unfortunately, if you've already increased your start boost to the maximum setting that doesn't give you surging, then there seems to be no way to get around this variance in boost pressure from low to high gears. I don't know if this is a limitation of the greddy unit specifically, or if it's something inherent to electronic boost controllers in general. The only two things that you can do to compensate is the following:
1. Set it to the "safest" of the settings that does not trip your limiter. To do this, tune the unit to your desired boost pressure in fifth gear.
2. Tune the "Lo" and "Hi" settings corresponding to having the boost maximized during the low gears and during the high gears. This would require you to manually hit the button to switch to the "Hi" setting when you shift to third gear or whatever you started tuning your "Hi" setting at. This is why Greddy makes the wireless remote switch that straps to your steering wheel to switch between "Hi" and "Lo" settings.
skool u
Jun 8, 2009 09:51 PM
chad86
May 13, 2009 06:13 PM
Spec-D@Tin
Dec 20, 2007 06:26 PM
parkerdw
Nov 19, 2007 07:18 PM
S_NeWb
Oct 18, 2006 11:16 AM
