Updates on my turbo setup
Old Jun 8, 2009 | 07:15 PM
  #21
LostMotion's Avatar
I add about 3% to number 4 based on EGTs.
Obviously my plenum isn't anything close to yours, but I'm surprised your #4 doesn't get a lot more air.
Old Jun 9, 2009 | 05:16 AM
  #22
Momentum's Avatar
I think that my manifold flows pretty evenly due to its size and raised velocity stacks. The stacks are center plenum so there's not a huge onrush of air to cylinder 4. That being the case the air distribution is virtually impossible to predict assuming everything is basically equal.
Old Jun 9, 2009 | 06:45 PM
  #23
Momentum's Avatar
Surprised nobody caught me on the poor placement of my oil temp sensor... Decided to change it tonight and added a crankcase pressure sensor while I was at it... leaving for the track tomorrow night fingers crossed.
Old Jun 10, 2009 | 01:20 PM
  #24
spdracerut's Avatar
Mind if I ask what EGTs you're seeing?
Old Jun 10, 2009 | 01:27 PM
  #25
Soul Coughing's Avatar
great setup. Where does the line that goes from the catch can and runs along the radiator support part go?
Old Jun 10, 2009 | 01:30 PM
  #26
LostMotion's Avatar
I don't know, I just know the results of the testing. I don't have EGT sensors on the car now -- this was done with a special header on an engine dyno. Also my car is NA.
Old Jun 11, 2009 | 06:50 AM
  #27
Momentum's Avatar
front right brake caliper came apart went through my rim, rim exploded took out my fender, headlight, and a rod end from my upper control arm. Found the caliper on track with 1 sheared off bolt and a sheared slider. Hard to tell what happened exactly but I know the bolts were tight. It appears like the outside part of the caliper (with the sliders on it) broke loose and hit the rim.
on the plus side I wasn't having any heat related issues or engine trouble
Old Jun 11, 2009 | 07:03 AM
  #28
camuman's Avatar
that sucks. def a plus that the motor was holding up well boosted hard on a track event.
Old Jun 11, 2009 | 08:36 AM
  #29
LostMotion's Avatar
Under_Pressure
Jun 10, 2009 10:57 AM
MB
Car Talk - Non S2000
63
Dec 3, 2008 09:18 AM
03silver2000
Jan 17, 2008 12:54 PM
slimjim8201
Feb 7, 2007 07:16 AM
cjb80
Jul 4, 2003 07:31 AM
