Vacuum system with EMS
Old Dec 18, 2005 | 11:43 AM
spoiled@21's Avatar
Default Vacuum system with EMS
The small black box that you have to move when you install the SC (with the little solenoid) and the secondary air system. Are they nessecary when SCd with EMS? I want a better vacuum connection to my blow off valve and I don't see the point in having all these extras that no longer function being attached and taking up space. I know alot of turbo guys take the secondary injection system out but can I with an SC? Can I just unplug everything and cap off the vacuum runners under the fuel rail? or does something else need to be done?
Thanks,
Alex
Old Dec 18, 2005 | 11:49 AM
folex187's Avatar
You can even lose the air pump in the drivers side bumper. However, if you lose that you will need to cap off the air lines taht go to it also. The stuff is far more useful sitting in a box in your garage.
As far as the vacuum pipes under the fuel rail- one goes to a solinoid that I believe does nothing as it does not function with the ems. The other goes to the intake manifold. Why not just get rid of these all together and use the port on the intake manifold for the BOV?
Old Dec 18, 2005 | 12:23 PM
spoiled@21's Avatar
that is what I wanted to know.
Old Dec 18, 2005 | 12:39 PM
Asura's Avatar
You can with EMS regardless of SC or turbo.
Old Dec 18, 2005 | 02:45 PM
Slows2k's Avatar
Save the parts incase you have to run the stock PCM again.
Old Dec 18, 2005 | 03:13 PM
spoiled@21's Avatar
I am sure the old garage shelf can stand a few more oem parts.
Thanks guys
Old Dec 27, 2005 | 10:56 PM
jakub2000's Avatar
I took it all out and ran the BOV line from the manifold.
aresk3b
May 17, 2013 12:41 PM
Lalasissyboy
Apr 27, 2013 07:18 PM
rsmatti
Feb 21, 2011 12:05 PM
SoCalIsMyLife
Jul 2, 2007 06:13 PM
Nick32
Apr 5, 2007 04:43 PM
