VAFC & 550's... gains to be had?
Old Sep 25, 2010 | 02:03 PM
teamvalorracing's Avatar
Default VAFC & 550's... gains to be had?
i have found thread upon thread of people who say, "yes use it! its super cheap and allows for a slight advantage over JUST the comptech FPR and ESM."(meaning: add the VAFC&550's along with the other 2 items)
then there are those who say, "hell no. just install the kit and go."
of course with the vafc, i could install a set of RC550s which would give me a little more room for a dyno tune to get the AFR's spot on. and not have to rely only on comptechs FPR.
weigh in your opinions here gents.
i am not going standalone. i am not going for 9 billion hp. i just want to see if the VAFC, some 550's, and a couple dyno runs with my tuner could get this ap2 into the 325whp range. or if i should just avoid all that and install it out of the box and go about my business.
thanks!
Old Sep 25, 2010 | 02:28 PM
s2konroids's Avatar
If only
You are retaining the stock ECU and using a VAFC2 therefore adding 550CC injectors will not work.The car will not run properly/idle due the ECU being mapped for 360cc injectors (pulsewidth+deadtime is different).
You need a standalone or greddy emanage etc.
Old Sep 25, 2010 | 02:40 PM
JawKnee's Avatar
Overly increase fuel pressure with the RRFPR, keep the stock injectors, and then use the VAFC to lean out/offset the increased fuel along with lowering VTEC to 4400 RPM or so.
Old Sep 25, 2010 | 03:42 PM
^ok. i was thinking exactly along those lines myself before i even started searching.
so the v-afc would be beneficial?
Old Sep 25, 2010 | 03:51 PM
JawKnee's Avatar
Especially if VTEC is currently engaging at stock-like 6kish. Lowering it to engage at ~4400/4500 with appropriate fueling is well worth it if you ask me.
I believe the original CT kits did not come with a lowered VTEC engagement, but if you were buying a new kit, I think it comes with a pre-programmed piggyback which offers a lowered VTEC engagement and appropriate fueling?
Old Sep 25, 2010 | 03:53 PM
see, i didnt know about that either. its heir ESM(electronic signal modifier) and i thought that was an A/F and Map sensor tricking device.
anyone got a recent comptech ap2 kit? 1220sl or not, the ESM is still the same.
Old Sep 25, 2010 | 04:17 PM
s2kadrenalin's Avatar
Spent all that money to cheapen out on a VAFC?
If you're going to run a piggy back atleast go with an EManage Ultimate.
Old Sep 25, 2010 | 05:06 PM
thats the thing. stock pulley and injectors etc, all run fine off stock ecu. so the standalone at those levels is pointless.
ive been down the AEMv2 road. and its totally unnecessary with the stage 1/base kit. just wondered if the vafc would allow for any tuning gains . not trying to run a 1500 and 400+whp here...
Old Sep 25, 2010 | 05:09 PM
JawKnee's Avatar
In any event, talk with s2000junky. He is running the first gen CT kit w/ AC and boosting around 9 lbs I believe (~360whp) and using a VAFC2 to do what I had mentioned.
2002silverS
Jan 5, 2007 07:19 AM
JDM Baller
Sep 7, 2006 10:11 AM
thejukster
Jan 5, 2004 10:52 PM
Reignman
Aug 29, 2003 06:15 PM
S2K_LA
Oct 30, 2001 02:23 PM
