Valve clearance
Old Jan 18, 2009 | 06:55 AM
John_Z's Avatar
Default Valve clearance
On the tight side or loose side with FI? Does it really even matter? Please share your thoughts.
Old Jan 18, 2009 | 08:04 AM
stena's Avatar
i am thinking the same thing. which one is better for FI.
Old Jan 18, 2009 | 08:17 AM
Slows2k's Avatar
Too tight burns valve seats. Too loose lowers valve lift, makes additional noise and causes additional wear.
Go with the the stock specs.
Old Jan 18, 2009 | 08:19 AM
stena's Avatar
I am at stock Spec,but stock says 0.25-0.29 ex i think and 0.20-0.25 in.. so which one..looser one or tighter one?
but definetly at stock.
Old Jan 18, 2009 | 08:22 AM
John_Z's Avatar
^That is what I meant. Stock specs allow for slop, so I wanted to know if there were any benefits by running the looser or tighter side.
Old Jan 18, 2009 | 08:26 AM
Jacko's Avatar
I have an modified head and F/I setup like John_Z as do many others I'm curious too.
Old Jan 18, 2009 | 08:31 AM
stena's Avatar
i have to say that the Valve clearance isn't an exact science but when you check for valve clearance do you leave them looser or tighter when you check them,i personally leave them looser if i can,not on the tight side.
Old Jan 18, 2009 | 10:59 AM
TRBOKEV's Avatar
I ALWAYS have went to the tight side of the stock specs. It will give you the best lift while still being "safe".
Old Jan 18, 2009 | 01:27 PM
Venomous S's Avatar
I always go with the tightest stock specs.
Old Jan 18, 2009 | 06:29 PM
Sideways's Avatar
Shordmcman
May 20, 2012 07:23 PM
nightcrawler7188
Oct 30, 2007 08:55 AM
GDM S2K
Mar 21, 2006 11:49 AM
synapse
Mar 22, 2005 07:50 PM
BlueS2000Boy
Jul 31, 2004 11:59 PM
