Valvetrain recomendation
Old Jun 6, 2011 | 06:00 PM
VTECSTYLE's Avatar
Default Valvetrain recomendation
Well i had a failure the other day and i dropped a valve and kaboom. cracked the #4 cylinder and f@#ked up the head and block, Was in 1st gear at like 7k rpm went to shift to 2nd gear and shut off. Not good.
In the process of building another engine.
Getting the short block from a friend that has aebs sleeved block Inline pro rods. cp pistons, arp head studs and some other good stuff.
also have a different cylinder head on the way. looking to get some new springs valves. and retainers and keepers
what is everyone running for valvetrain not stock stuff. that you would recommend for a high boost app. 600+ hp/
Old Jun 6, 2011 | 06:14 PM
red@9k's Avatar
from what I read ferrera is the way to go
Old Jun 6, 2011 | 06:19 PM
passmans2kny's Avatar
^agree
Old Jun 6, 2011 | 06:25 PM
VTECSTYLE's Avatar
does anyone know if s2000 oem valves are friction welded two piece valves like most oem honda engines?
Old Jun 6, 2011 | 06:46 PM
DFWs2k's Avatar
Ferrea valves, supertech springs and retainers is the way to go
Old Jun 6, 2011 | 07:10 PM
erikvanden's Avatar
Sorry to hear about it John. Let me know if you need me to come down there and give you a hand with the rebuild.
Old Jun 6, 2011 | 07:34 PM
ScorpioMk's Avatar
Same thing I've got in my motor and same combo all my friends run in their hondas. No issues.
Old Jun 8, 2011 | 06:33 AM
VTECSTYLE's Avatar
Should i get new valves or just get springs and retainers and call it good?
Old Jun 8, 2011 | 06:56 AM
Sideways's Avatar
Lighter aftermarket valves, lighter retainers, springs, guides. If going turbo I suggest the inconel exhaust valves for heat resistance.
In flow testing about 6-7 years ago we found the Ferrea valves we tested flowed 1% better than the Supertech.
I don't have the details as to which valves exactly.
alexrosiu
Aug 31, 2015 06:56 AM
mr-pitts
Jul 29, 2015 05:04 AM
youngkilla
Jun 8, 2014 07:43 PM
boostedAT9K
Jun 17, 2012 01:18 PM
lookinco
Dec 10, 2008 09:55 PM
