Vibration
Old Oct 20, 2014 | 06:42 AM
Dig8r's Avatar
Default Vibration
Took the car out for the first time .Huge vibration coming from the back of the car whilst on low revs like 2k or so. I have a v160 and a steel drive shaft from DSS and 8.8 diff. Have somebody had same issues with the same set up ?.
Old Oct 20, 2014 | 07:10 AM
EOE's Avatar
EOE
Unbalanced Drive shaft?
Worn Axle/Axles?
Checked Diffy, Tranny, etc mounts?
Old Oct 20, 2014 | 07:14 AM
Dig8r's Avatar
I will start from removing the dump tube it is touching the engine and making a rattling noise. I will try the drive shaft after, we never aligned it after we installed it.
Old Oct 21, 2014 | 09:50 AM
Dig8r's Avatar
Old Oct 21, 2014 | 09:53 AM
Dig8r's Avatar
The vibration is coming from the bell housing very strange. When i drive the car and put it on neutral gear the vibration goes away. Any suggestions? Would help a lot.
Old Oct 21, 2014 | 03:59 PM
Monacos2k's Avatar
If you have aftermarket exhuast possible its vibrating if close enough to something. Might check motor mounts if you replaced clutch. Unless its clutch buzz from heavy clutch.
Old Oct 21, 2014 | 07:30 PM
Chance S2K's Avatar
I can't think of any trick other than going over all the bolts on the bellhousing and checking that they're torqued down properly. Should also check the trans mount and make sure it's secured.
Beyond that though I'm wondering if there's any possibility there could be an issue with the pressure plate/flywheel torque. Just anything that could cause rattling by the bellhousing. Check that the clutch fork is properly pulling the TOB?
I'd just start checking all your bases until you hit something.
Old Oct 23, 2014 | 06:54 AM
Dig8r's Avatar
I am missing spacers from the drive shaft. This might be the issue. I need to get some info regarding them. My drive shaft bolts directly without spacers.
Old Oct 24, 2014 | 09:42 PM
ROFLv8's Avatar
I had the same problem.. All I did was raise up my coils in the back and it went away..
FreshDonny
May 30, 2018 11:38 AM
jor-don
Jun 16, 2014 07:43 AM
golfnut311
Mar 18, 2013 05:20 PM
EssToOfouzEn
Jun 28, 2012 10:24 PM
motoinfantry
Aug 22, 2009 06:39 AM
