Vortech rebuild
Old Sep 27, 2008 | 02:12 PM
John_Z's Avatar
^Keep in mind, even though your bearings are good to 59k, your impeller efficiency may not be up to snuff. Are you upgrading the trim as well?
Old Sep 27, 2008 | 02:55 PM
Enthralled's Avatar
not at this time..I'm thinking some time next year, if I still have the Vortech that is..
Old Sep 27, 2008 | 03:02 PM
Jay-Z's Avatar
what do you think of this with the 59000 bearings?
http://cgi.ebay.com/ebaymotors/Vortech-S-a...emZ350100844188
Old Sep 27, 2008 | 06:50 PM
911GT2's Avatar
Wow look at that CNC Impeller what u guys think about that?
V+ Impeller: Our V+ impeller is cut from billet on a 5-axis CNC mill, allowing us to use higher-strength alloys, and balance it to higher tolerances. We cut in more aggressive inlet curls and progressive vanes that are computer-designed for optimum flow inside the casing. Each impeller is spin balanced to 0.006 grams/inch, and designed to operate at up to 60,000 rpm. This Impeller has been more than a year in development and testing, and so unique that we have a Patent Pending on it.
On-car and on-bench testing reveals that the V+ impeller moves about 15% more air ACROSS THE ENTIRE RPM BAND. See actual data sheets below from dyno testing. We were able to bring the boost in much sooner, which translates into USEABLE HORSEPOWER. Now your S-Trim Vortech can produce almost the same 1200 CFM as a T-Trim below 50,000 rpm (impeller speed) and more if you spool it up to 60,000!
Old Sep 27, 2008 | 07:41 PM
Sideways's Avatar
That ebay impeller is a direct drop-in replacement for the S-trim impeller. The T-trim is larger and requires machining to install.
The T-trim intake is 1/4 inch larger at 3-3/4 inches and performs well with a 4 inch intake.
Old Sep 28, 2008 | 12:08 AM
911GT2's Avatar
So would that impeller be a good upgrade for the standard S trim
Old Sep 28, 2008 | 05:49 AM
Sideways's Avatar
That is a question I can not answer. We need some members to run them and see. It could be worth 30 or 40 rwhp and an extended rpm range.
Old Sep 28, 2008 | 10:27 AM
911GT2's Avatar
[QUOTE=Sideways,Sep 28 2008, 05:49 AM] That is a question I can not answer.
Old Sep 28, 2008 | 12:09 PM
Sideways's Avatar
Originally Posted by 911GT2,Sep 28 2008, 11:27 AM
that prety awsome I want to try it when I get the new bearing, also what is a "T Trim" upgrade cost?
It's about a grand.
Old Sep 28, 2008 | 03:07 PM
911GT2's Avatar
Originally Posted by Sideways,Sep 28 2008, 12:09 PM
It's about a grand.
Nice is that price$ from Vortech?? also is that 1K include everything like bearing and such .
