vortech returned to the oil pan
You're excluding the flow of oil coming from the topside in your analysis. Your setup, while seemingly functional, is impeding the return of oil to the pan. Because your oil line is longer than most turbo guys, you're less likely to have an issue. What size restrictor does your S/C use (if any)?
The way I understood this thread (and as seen above) it was showing a functional way to route the oil return for a supercharged setup. Why are we even talking about how/why this wouldn't work on turbo setups? He never said you turbo guys should do it this way.
Originally Posted by speedjunky01' timestamp='1341592606' post='21838782
There is no chance of back up think about it
