Vortech Supercharger
Old Dec 2, 2011 | 01:04 PM
sarge1's Avatar
Default Vortech Supercharger
Hey guys I am trying to figure out if I will need a rebuild or what this problem could be. My s/c ihas a little shaft play and the pulley belt is jumping a rib during the dyno session and currently still is. I am still getting full 10 psi. We loosened it and put it back on correctly and it still jumped. The belt doesn't move after it jump that one rib and pretty much stay put. I didn't have this problem before (312hp 198tq) now (350hp 220tq after retune) both at 10psi. Have anyone ever ran into this situation before?
Old Jan 23, 2012 | 09:08 PM
sarge1's Avatar
I still have this problem guys. Can anyone help?
Old Jan 23, 2012 | 09:23 PM
TheCarGuy2021's Avatar
How much shaft play are we talking?
Any odd noises coming from the unit?
Have you checked all of the S/C drive pulleys for proper alignment?
What kind of pulley is on it?
Ever consider one of the pulleys with a ridge to prevent belt jumping?
Mine kept jumping ribs last year, this was why. I doubt this is your reason, though.
Old Jan 23, 2012 | 10:01 PM
Sideways's Avatar
The raised lip (ridge in the above post) makes all the difference.
Vortech pulleys are lacking the raised outer part of the pulleys that holds the belt in place.
A little too much torque to the belt and .......... belt jump.
ASP pulleys have the raised lip as do many aftermarket pulleys.
https://www.s2ki.com/s2000/gallery/i...7-dsc00167jpg/
The Reichard Racing pulley is only available at 3.6 inches or less.
https://www.s2ki.com/s2000/gallery/i...0-dsc00160jpg/
Get a raised lip pulley and be done with the problem.
Old Jan 24, 2012 | 11:11 AM
NH_s2k_Guy's Avatar
So this may be a totally off the wall question but, would this belt jump cause the SC to bog somewhat at mid throttle when the car is at operating temperature or hotter?
Old Jan 24, 2012 | 02:50 PM
Sideways's Avatar
Make the change and tell us if it eliminated the mid throttle bog.
Old Jan 24, 2012 | 03:59 PM
NH_s2k_Guy's Avatar
Ok I'll let you know in 3 months.
Old Jan 31, 2012 | 08:24 PM
sarge1's Avatar
Ok, thanks for the info. Where is a good place to get the ASP Pulleys?
Old Jan 31, 2012 | 08:35 PM
Sideways's Avatar
http://autospecialties.com/
Call them, the pulleys are not listed.
boszyen
Jul 13, 2008 10:09 PM
martus2k
Jun 3, 2006 11:41 AM
johninator
Sep 17, 2005 03:03 PM
Anthonymv
Oct 3, 2004 10:02 AM
GaryRudolph
Jan 21, 2004 09:28 PM
