Vortech V2 S/C map
Old Mar 6, 2013 | 03:04 PM
Jjnormanyale's Avatar
Default Vortech V2 S/C map
Hey guys,
I am looking for a map which will help me start the engine and make sure everything is running fine before I tow it to tuner. Don't want to tow to tuner and find out something wrong plus the map will help reduce cost by 150-200 dollars. Help will be much appreciated.
Regards J
F20C
Vortech V2 Supercharger Kit,
pulley size 3.55 inch
spearco large heat exchanger,
bosch cobra water pump
ID1000s injectors
AEM V2
Aem wideband/Uego guage
Hondata Intake Manifold Gasket
70mm throttle body, 3 bar map sensor
290lph fuel pump,
76mm manifold, decat and single exit exhaust,
Clutch Master FX850 twin disc clutch kit
mishimoto rad,
19 row oil cooler,
mugen thermostat and fan switch.
Also got cam keys havnt installed them yet.
Old Mar 6, 2013 | 03:21 PM
camuman's Avatar
Aem ems has base maps to start the car. And your tuner will prolly send you one also to get car started to verify all good. Regardless towing is recommended to tuner just in case tuning goes bad.
nemesisryder0627
Feb 25, 2018 11:59 AM
MPS2000
Sep 14, 2012 10:03 AM
