Vortech vs Comptech - Specifically their Brackets
Old Feb 27, 2018 | 04:14 AM
  #31
RolanTHUNDER's Avatar
Originally Posted by s2000Junky
I did it for quite a few years till I eventually put in a modded baffle pan with another bung for the sc. It takes two wrenches to undo/do and its an aluminum earl type fitting, so you have to be extra careful cross threading, its kind of a pain in comparison but its totally doable.
Ive never run one and not familiar with the brand, but ive seen these with multiple ports so you probably could. Id get a good one though. Its one part you dont want to cheap out on from some no name Ebay option. Blow motors when things that like fail because of crappy metallurgy.
Glad to hear it worked for you until you changed the pan to a baffled one. Must be for all the tracking you do
What type of fitting/s will I need to use the sump plug hole as a return line? I'd assume auto parts stores would carry the needed parts?
I hear you. I'm a supporter/believer in quality brand names, not just for the "swag" of a premium/good quality brand but because of the legit proven quality behind the name. Tegiwa seems to be a good quality brand that isn't too expensive across the board. I'll research them more before taking the plunge on their filter sandwich. I see the VT kit included a little oil feed fitting between the pressure sending unit and the block. I don't have it from the looks of it. Anyway even if I did I would not be able to wire up an oil pressure gauge using that VT piece which I'd like alongside my soon to acquire AEM UEGO.
Other thing I noticed is you can't run an ETD with a blower kit installed...or can you? I like the idea of added damping assisting the engine mounts with the extra load of a blower kit up front...
rikhemi
Jul 9, 2010 04:00 AM
mike10
Κινητήρας - Μετάδοση - Περιφερειακά
17
Nov 12, 2008 10:44 PM
lazykiwi
Feb 14, 2006 11:51 AM
sgosling
Dec 7, 2005 11:47 AM
JayDeeEm
Mar 24, 2004 01:29 PM
